1 - 4 of 4 Posts
-I know that the boost level on each installation will differ for the same pulley ratios dependant on various factors like whether there is an intercooler fitted/intake temps etc. but was just wondering what the boost level difference was likely to be between the following:
stock 130 crank/62.5 nose
150 crank overlay/67.5
-I'm only running about 6-6.5psi at the moment with 130/62.5 & wish to know if it's worth me changing it to 150/67.5 (I don't want to risk 150/62.5 at the moment).
Blue is the colour - not the mood
I was getting near on 10 psi with my 1.8 with 150/67.5 pulley ratio, that was before I intercooled it and fitted the Adaptronic.
I only had a power card and JR timing controller at the time so really think I was chancing it at the time.
Oh just for the record I was still only getting about 10 psi with the 150/62.5 pulley ratio but that was after I intercooled it.
Michael
Mine's a Beer
The problem with the PSI figure is that it is more a measure of the restriction than the amount of air being moved
My 99 with 150/67.5 was about 10psi un-cooled but actually is 7.6 with a charge cooler and 7 when you add WI to that
1 - 4 of 4 Posts
