Im an electrical engineer in the food manufacturing industry. I work on all voltages ac and dc. Im 49 and being doing it far too long. Apprentice trained from 17yrs old.
Something strange has happened to your car and i dont think your being told the truth....
Short circuit. Basically live and neutral being joined together without a load inbetween them. Massive current flows. Enough to create an arch. If done at a battery with no fuse connection can cause harness damage i.e melting cables etc. Most jumpstarters have short circuit protection.
Jumping starting a car ignition should be off whilst clamping leads on. If it was jumped incorrectly with ignition on and lights on i.e those circuits turned on then the Individual circuit fuses should blow but a fuse is quite slow acting when compared to say household circuit breakers.
A spike is an overvoltage situation that is a short time period. Again high voltage higher current. Fuses should blow.
Ecus are very susceptible to spikes as the components are small and the circuits tracks are not designed to flow hi current.
Id say its either you alternator or something bad happened at garage...alternator needs testing...bench test can be done as if faulty could damage another car.
I got roped in looking at a go kart project ebay special awhile back..
12v motorbike battery on it.
Would start and run blow the headlight and cdi unit when revving (Basic motorbike ecu).
Headlight bulb was a 6v...little gokart was a 6v system lol.
