So, engine is all back together now, replaced all the coolant hoses, tried to get a nice spring clamp on the rear reroute pipe but it's so tight it doesn't quite fit, tried to be clever, then filled it up with water to check and it all leaked our so not so clever 😂
20220219_134553 by Ben Hawkes, on Flickr
Managed to sort out my alternator tensioner problems, turned out somehow I had a mk2 tensioner block which is threaded, and the alternator was also threaded so they never tightened up properly!
Drilled the thread out of the block and added some safety nuts for added safety!
20220219_135842 by Ben Hawkes, on Flickr
Then started on the oil filter relocation and cooler.
Fitted the bit to the engine no problem
20220219_212439 by Ben Hawkes, on Flickr
Going to make a little bracket that mounts to the engine to stop it from twisting, as apparently with the movement of the engine compared to the lines they can start to undo!
The filter side of this kit was quite badly machined, lots of swarf that had been anodised in, and it looked quite restrictive!
20220219_164153 by Ben Hawkes, on Flickr
Attacked it with the die grinder and got that looking much better!
20220219_194301 by Ben Hawkes, on Flickr
Fitted the filter, then found a nice spot on the wheel arch for it to live! This means I can change the oil filter mess free without having to drop the undertray!
20220219_204825 by Ben Hawkes, on Flickr
Added a couple of extra rivnuts ready to make a shield for it, just to stop any Debris etc smashing it!
Next job is to fix the leaking coolant line on the back of the the engine, then get this oil cooler mounted and get the lines made up!
I've ordered the correct spanners and vice clamps to make up the an lines so hopefully will go without a hitch!
