401 - 420 of 451 Posts
Discussion Starter · #401 ·
Great progress, I crawled around in the rain under my car today, nothing as successful as you! with that intake have you ever considered taking the air from the windscreen bulkhead? just a quick 90 degree bend and you've got a cold air randell-style intake to the supercharger.
Yeah crawling under a car In the rain is no fun is it!
There isn't quite enough room to get a proper randal cowl intake in there,
but I am planning on making a little duct out of some left over pipe and steel plate,
Hopefully it will be able to feed cold air down onto the filter from the scuttle! And also make use of the air from the TSI's
Discussion Starter · #402 ·
No work on the car today,
Just in my make shift spray booth!
49996201297_1b69968c8c_c.jpg20200611_102546 by Ben Hawkes, on Flickr
49995429648_b970f4ed66_c.jpg20200611_111453 by Ben Hawkes, on Flickr
49996201067_c379f5f825_c.jpg20200611_114016 by Ben Hawkes, on Flickr
49996200957_322bedd7ec_c.jpg20200611_160645 by Ben Hawkes, on Flickr
49995429238_12b7ff6ff7_c.jpg20200611_160705 by Ben Hawkes, on Flickr
49995429123_1442b1cdcb_c.jpg20200611_160711 by Ben Hawkes, on Flickr
Considering my skill and facilities, I'm about 8/10 happy with this!
If it wasn't for a few spots of laquer, I would be almost 10/10 with it!
Hopefully a flat and polish should see that all smoothed out and looking good!
Tomorrow my boost pipes are getting some ceramic gold paint and then it's almost ready for mapping!
Discussion Starter · #404 ·
Why have you fitted a dump valve when you already have a bypass?
They do different roles, I used to get a bit of belt slip at high rpm when letting of the throttle or quick gear changes.
Assuming its the air trying to stall the rotors a dump valve was a good choice.
And it seems to do something as you can feel air getting vented out of it at lowish rpm revs, even with the bypass fitted and working.
Discussion Starter · #405 ·
Just a bit more ceramic coating today!
And my new hardtop spoiler arrived! This time not cracked like the first one!
49999377217_f94e7c2b60_c.jpg20200612_094300 by Ben Hawkes, on Flickr
49999377197_1fb4088a59_c.jpg20200612_094409 by Ben Hawkes, on Flickr
Really happy with that paint, it covers nicely! And as long as it works like it's suppose to on the manifold I'll be happy! This took about quater of a pint to do both the exhaust and intercooler pipes, so still got plenty left
Discussion Starter · #406 ·
Few bits done today!
50006525376_8a28b230a4_c.jpg20200614_130036 by Ben Hawkes, on Flickr
Cut down the pipe for the BOV and the silicone reducer a bit, and mounted it up along with the IAT sensor.
Couldn't fit it back on the car as I'm waiting for a clamp for my coolant overflow pipe! But the other side is back on!
Also made a quick bracket to stop the intake waggling around! It's out of light enough gauge metal it should be able to flex a bit of it needs to due to engine movement, but should hold it tight enough to not be annoying!
50006625831_07597163e8_c.jpg20200614_164106 by Ben Hawkes, on Flickr
And tomorrow plan for a little randal cowl intake feed, not going full enclosed feed but just a feed, I can see if it helps by blocking it off and doing back to back runs checking the IAT readings!
50006780597_f36df7c2e6_c.jpg20200614_164113 by Ben Hawkes, on Flickr
After that I cracked on with the hardtop!
Refitted all the seals and catches that I removed, just waiting in a pair of side catches to arrive, hopefully tomorrow!
Got some brand new bits for it! The little rubbers that go on the rear mounts
50006881787_db5a2e9d13_c.jpg20200614_171819 by Ben Hawkes, on Flickr
And then test fitted the spoiler!
50006779692_9698e955b9_c.jpg20200614_175311 by Ben Hawkes, on Flickr
50006524351_028a9a195c_c.jpg20200614_175306 by Ben Hawkes, on Flickr
50006779982_f00c393d96_c.jpg20200614_175301 by Ben Hawkes, on Flickr
50005997118_9df056d8b3_c.jpg20200614_175246 by Ben Hawkes, on Flickr
50006524871_483fd618e4_c.jpg20200614_175258 by Ben Hawkes, on Flickr
Looks really cool! I like it!
It needs a bit trimming off the two wings as they are slightly too long, I think because I don't have the window seal anymore, but with them trimmed down it should fit really nice, then it's just paint and stick it on!
I finished off today putting a bead of tiger seal around the rear window, I'm not refitting a rubber seal as I thought it looked shit, and it requires removing the window to fit which I'm not doing! The window has 3 small leaks from up close pressure washing, so this should both seal them up and neaten up the edges!
50006779632_19a32834d2_c.jpg20200614_190402 by Ben Hawkes, on Flickr
And that's it for today! I'm hoping that by the end of this week the car should be ready for mapping, and the hardtop and spoiler should be done and on the car!
Discussion Starter · #407 ·
Made my scuttle intake today!
not sure if it will actually function or not, but it was good fun to fabricate, and looks kinda cool!
50010274826_f484788b03_c.jpg20200615_093833 by Ben Hawkes, on Flickr
50010535047_c1bb451e6b_c.jpg20200615_095254 by Ben Hawkes, on Flickr
50010274176_1f7eb06910_c.jpg20200615_101715 by Ben Hawkes, on Flickr
50010274291_93699e3dd1_c.jpg20200615_102637 by Ben Hawkes, on Flickr
50009742533_ae2587ea42_c.jpg20200615_114655 by Ben Hawkes, on Flickr
once that was made and painted, it was finally time for the new filter to go on!
50010273731_79d7c14164_c.jpg20200615_134554 by Ben Hawkes, on Flickr
50010273706_8165c15bf6_c.jpg20200615_135047 by Ben Hawkes, on Flickr
and then the rest of the bay goes back together!
50010533887_6d8cc88d85_c.jpg20200615_135043 by Ben Hawkes, on Flickr
took it for a test drive and there was no leaks, just some monumental backfires! need to tweak the map a little and take some of the ignition retard out of the overrun area, but hopefully ill give it a test for a week or so and then go get it mapped!
then onto the hardtop!
the side latches and bolts turned up today, so I got them fitted and this evening it went on the car!
50010533457_f2d77cfecb_c.jpg20200615_174341 by Ben Hawkes, on Flickr
50010533417_bedebf2deb_c.jpg20200615_174345 by Ben Hawkes, on Flickr
50010272871_fe355cd47c_c.jpg20200615_174351 by Ben Hawkes, on Flickr
50009742013_770fc6797c_c.jpg20200615_174331 by Ben Hawkes, on Flickr
so happy with it! the spoiler has been shaped to fit but not painted yet, so its just on with one bit of masking tape!
I had to adjust the the latches as it was bending up funny in the middle, spent a little while trying to adjust the right hand latch and striker plate, to find that all the adjustment is apparently in the left one!
looks and fits much better now anyway, next job, more paintwork!
Just noticed you have dual TB's we are on different setups
Discussion Starter · #409 ·
Ahh fair enough! Yeah you can still have a dunp valve with single TB but not as important!
Discussion Starter · #411 ·
looking good, I'm very interested to see if the intake will work passively. I guess if you wanted to you could record air intake temps with it open and blocked off to see if there was a difference.
That is exactly the plan!
I'm just trying to get real dash working in my phone so I can test differnt things easily! It's a bit hard to see the values on a laptop sat on the passenger seat!
Pointless when the single TB is pre charger
Discussion Starter · #413 ·
Oh definitly! Either of the other two options though!
Discussion Starter · #414 ·
Started work on the last bits of painting yesterday!
Bow the spoiler is shaped to fit, it was sanded all over with a bit of 180
50018440026_d0e20b55be_c.jpg20200617_201302 by Ben Hawkes, on Flickr
And then I mixed up the rest of my epoxy primer and got it sprayed
50017911448_d51a980cd6_c.jpg20200617_203541 by Ben Hawkes, on Flickr
I still had plenty of epoxy primer left in the gun though, spoiler didn't need as much as expected, so I quickly got the slam panel ready for paint and sprayed that too!
50018439871_93a6bf15cb_c.jpg20200617_211942 by Ben Hawkes, on Flickr
I think that's been sprayed 4 times Now, so as I started sanding back the old white paint and laquer, the layer underneath started pealing off!
Before I knew it I was having to sand it back to bare metal! Took a bit longer than expected but its done and for the best!
50018439801_4d93340ba9_c.jpg20200617_215041 by Ben Hawkes, on Flickr
Just about to head out and start sanding that back ready for filler primer, then hiofully get that sanded back this afternoon and I'll get colour on the slam pannel, spoiler can wait till tomorrow!
Managed to get the spoiler and slam panel sprayed in filler primer, and then the slam panel in colour!
50020912407_d5e8bb67ca_c.jpg20200618_205217 by Ben Hawkes, on Flickr
Colour always looks a bit odd before laquer!
I also made use of the rain to wet sand the hardtop! Went from 1000 grit up to 3000, and tomorrow it will get cut polished and waxed! Hopefully it's worth all the effort for a good bit of shine!
50020122308_5d2a53045e_c.jpg20200618_103055 by Ben Hawkes, on Flickr
50020122453_3200af8506_c.jpg20200618_103046 by Ben Hawkes, on Flickr
50020912442_b451772328_c.jpg20200618_183804 by Ben Hawkes, on Flickr
Aiming to get the spoiler in colour and clear tomorrow too, so hopefully it can get stuck on early next week!!
Other than that I've taken it for few little test drives and all seems well! Going for a couple of longer ones next week just to check everything is good before I take it to get mapped!
Discussion Starter · #416 ·
Well the rain halted the polishing this morning!
Al instead I got the spoiler in colour, and then both spoiler and slam panel lacquered!
50022626642_81816efa4b_c.jpg20200619_111042 by Ben Hawkes, on Flickr
Hopefully both will be fitted on Monday!
I also had my USB otg cable arrive today.
Real dash on the phone was so easy to set up, so u can now use it to monitor stuff, such as boost and intake temps!
Discussion Starter · #417 ·
So much effort to polish the hardtop!
Don't know if it was just bad technique or what but it took an age to get the hardtop looking half decent today polished up!
I'm not 100% happy with it but it's good enough, and not bad for a first bit of proper bodywork sprayed in my garage!
50024229892_cfb055eebd_c.jpg20200619_161558 by Ben Hawkes, on Flickr
50023426003_aab95d9f16_c.jpg20200619_163516 by Ben Hawkes, on Flickr
50023426203_76c4d1ee41_c.jpg20200619_163503 by Ben Hawkes, on Flickr
50023426063_37c2e6c32a_c.jpg20200619_163513 by Ben Hawkes, on Flickr
Spoiler is looking quite good so I won't be cutting and polishing that, just a glaze and wax once it's stuck to the hardtop! Which should be happening Monday!
Loving all these updates, you are doing a cracking job - the car looks great!
