Seems you need to have the same number stencil on the dash binnacle as one you wish to replace for whatever reason, mine was pulled out to fit a mileometer when i put it back only the rev counter and water temp worked, recently had the dashboard out, cleaned it repainted the steel bar which locates it and revamped it rubber washers on fixing points and when the binnacle was replaced nothing worked. i understand from another mx5 owner with much more experience than me on mx5s that they all operate through the ECU, I have checked mine for breaks and corrosion, the only thing that seems to work is the bulb which flashes when trafficators are operated.. is there a main fused p0wer source which may have blown, i know i didn't haul it around when working in the area, not my first venture around dashboards.. anyone?? w
