1 - 4 of 4 Posts
changing gear is over rated
Already read something about this here but search is failing me.
For an N/A car most of the top of the fuel map isn't used, so do you edit the table by just changing the fuel load in the left side of the table? if so what max do you use for an N/A engine?
Also can you set the table to have the first 50% entries cover say the first 30% of the map so you get better fine tuning on part throttle?
cheers
well did it and it seems to work.
I was wondering this to, for my spark and fuel. I only get 150odd kpa, so should I make the top cell 160 kpa and scale accordingly? I wouldn't want to reduce resolution down low as it's as needed there as anywhere surely?
Thats what I did, values closer together at the bottom, 30-35-40 etc spreading out at the top
1 - 4 of 4 Posts
