pop your main relay out in the engine bay and check the plastic around both the connector in the car and the relay itself
Thanks, will do 👍. (pretty sure i had a look at it last year, as, if i remember its located next to the fuel relay, but ill definitely check it again.)pop your main relay out in the engine bay and check the plastic around both the connector in the car and the relay itself
Thanks reverant, i havent noticed the tach guage bouncing, but i may well have not noticed if it only bounces a little.. Ill have a look into how to do the composite log, as ive not done any data logging yet, can this be done via the free version of tunerstudio?, unless its done via other software, i have somthing in my head saying mega log viewer? or something like that? 👍Its either the crank or the cam sensor. This is very common on the Mk2/Mk2.5 engines. You will also notice that the tachometer gauge bounces when it happens. You can get a composite log when it happens and it will show whether its the crank or the cam.
Thank you 👍👍👍It's done through Tunerstudio. Click on the "Diagnostics & High Speed Loggers" tab. Select "Composite Logger" from the Logger Type. Click Start when the problem appears.
Well at last, now its warm outside, captured it happening. Not sure if the engine is supposed to be running or not when capturing it, but it wasnt, as the car died quickly in traffic and i had to push the car onto the kerb. When trying to start, the fuel relay was not clicking at all, just dead as the car was too hot for the clicking to happen it seems. But the best i could do is below.. Anyone able to understand what im looking at?It's done through Tunerstudio. Click on the "Diagnostics & High Speed Loggers" tab. Select "Composite Logger" from the Logger Type. Click Start when the problem appears.
Thank you 😱👍👍👍👍The cam sensor is dead.
