1 - 9 of 9 Posts
Randomer
I'm on the lookout for some larger injectors to fit when I get around to installing the Adaptronic, ideally I'm looking for something in the 440-550cc range.
There are these RX7 460's on ebay, but the part code (195500-1350) is different from the code I've seen listed on various FAQ's??
RX-7 NA 440cc - Blue Top #195500-5740 89-91
RX-7 NA 460cc - Red Top #195500-2010 89-91
RX-7 TURBO 550cc - purple top #195500-2020
Maybe an error by the seller? are the injectors in the link suitable?
Am I correct in saying that at the injector size I'm looking at getting it will be fine to go for high impedance "saturated" type injectors without any side-effects on idle ability?
cheers, Jim.
This guide lists them:
linky
1986-87 RX-7 195500-1350 Peak and Hold 460cc Red Top
1988 RX-7 195500-1350 Saturated 460cc Purple Top
but to add to your dilema, those ebay ones look orange, not red or Purple
Randomer
linky
Thanks for the info. The injectors I linked to have probably changed colour a bit due to heat and age, but I'm in no desperate rush to buy some so I think I'll hold out until another set in good nick comes up for sale.
Missed some RC 440's on ebay the other night, so there are plenty of opportunities to get hold of some suitable ones.
If you want PnP you need the 2010 or the 2020 IIRC. 1350's have square plugs.
ninja is selling some rc440's in the sale thread on here for ?180 i think
Randomer
yep, but I'm buggered if I'm going to pay ?180 for the same things that went for ?102 a few days ago (if they are the same that is). I should've stuck in a higher bid whilst I had the chance!
Plug & play isn't such an issue, as long as the pigtails are there it's easy enough to wire them in, but thanks for the info Craigo I'll keep an eye out for those.
1 - 9 of 9 Posts
