1 - 2 of 2 Posts
As per the title, some time in the next couple of weeks I'll be fitting my new cat back exhaust and decat pipe onto my 1.6 Mk1I figured I would need new gaskets at the same time, but how many, which ones and where is cheapest to buy them?
I presume one of these:
http://www.autolinkmx5.com/gasket-exhaust-downpipe-to-cat-mx-5-mk1-70-p.asp
plus the equivelent for the other end of the cat. Is there one for the mid pipe to back box join? If so, will this be mongoose specific?
Randomer
yes you'll need one for the downpipe to decat joint, one for the decat to catback (midpipe) joint, and depending how your backbox section goes on you might need one for there too (some backboxes have a slip joint rather than a flanged joint).
I always go to my local motorfactors who have a big display with loads of different exhaust gaskets on it, take one with you to make sure you get the right one. I would think the Mongoose exhaust will use the same gaskets as any other exhaust system.
or try giving Autolink a call and tell them what you're after.
1 - 2 of 2 Posts
