Is the Exhintake cam swap worthwhile on a Mk 2, specifically a 1.8i S, and if so, is any exhaust cam from a Mk2 1.8i viable, or are there different profiles between models?
Thanks in advance for any help offered.![]()
I guess that must be something to do with how the cam gear is mounted to the cam then. I think the VVT mechanism fits in place of a cam gear (which makes sense as it has to advance/retard the cam timing). I'm sure a good engineer could still find a way thoughThe VVT cam as I understand it is completely incompatable with a 'normal' cam.
I would say 10 at least. The yanky cams from one of the write ups have less lift than the jdm ones.Brilliant. Thanks for the followup. I will give this a try as soon as i can get hold of a spare cam and new timing belt kit. So we're looking at 5bhp as a conservative figure, going on what i've read.
Let me know please if I have understood this the right way:will do but the classic advance the the inlet 2 degs and retard the exh by 2 always works on twin cams but.....every engine is different . I had a spare engine with 2 spare pulleys so drilled one at 197.5 and one at 199.5 and the latter performs better. The accurate way to do it ( hindsight is great) would be to use a dial gauge to find peak lift on the origional inlet cam (allowing for the dwell at peak lift) and attach a pointer to line up with its I MARK notch and then install the shortened exhaust cam, find the peak lift and mark its pulley.
EDIT EDIT EDIT....
dont know why i put 19 teeth on last post, should read 20..........was mixing up the 19 between marks when doing a timing belt change. IT SHOULD HAVE READ...........
To MX5rc....... i have just checked the counting teeth method and verified it with the pulley i drilled accurately at 197.5 degrees.
So, forget all the previous , mount the new shortened exhaust cam in place of the intake cam and put the pulley on with the I lining up with the dowel . Count 20 teeth from the mark(indented)above the I on the pulley clockwise and make a new mark. This is your new mark and lines up perfectly with the drilled one. 199.5 suited my engine better but ill wait to get adjustable pulleys and a dyno session before i know the best timing figures.
It makes a huge difference - the Mk 2 has the cam angle sensor picking up the cam angle from the cam pulley. If you slip the belt around 20 teeth on the oem pulley to get you your new cam timing, it will bugger up your CAS readings and I would imagine you'd get at least a Check Engine Light and at worst the ECU won't be able to run the engine.I'm very sorry for the dumb question (again), but, you mean setting the new mark at 20 teeth counter clockwise?
So 20 teeth clockwise "=" 197.5 deg pulley drilling, and 20 teeth anti clockwise "=" 199.5 deg drilling?
I've got an mk2, does it make any difference?
