1 - 4 of 4 Posts
Hi, I have a pal helping me towards my turbo conversion and the last part is the injctors. He says go for EVO 560cc injectors. He also says they will need a resistor in the wiring to each one for it to work propperly. Just checking with you guys before I spend my cash will it work?
I am doing the turbo conversion properly with a MSPNP ecu. Thanks
member
if they are low imp injectors then year you'll need resistors running on the original MSPnP. Think MSII and MSIII can run low imp injectors?
However, if you're spending north of £100 on them (which if you're getting them cleaned and tested i expect you will) then personally i'd get new Bosch EV14 injectors from Fuel Injector Clinic or Injector Dynamics, anything between 525cc and 725cc will do you. These are high impedance and are available as plug and play. you'll be able to idle and tune much better with these new injectors rather than the old design.
1 - 4 of 4 Posts
