I finally managed to get the Emanage blue hooked up to my ECU and have a couple of problems. Firstly, it will only fire up if I remove the Emanage ignition harness. I originally cut ignition 1 and 2 on the harness and connected them as per the instructions, but it won?t fire up. The instructions say:
Ignition 1 - blue/white wire to ECU
blue/black wire to Sensor
Ignition 2 - Orange/white wire to ECU
Orange/black wire to Sensor
Am I missing something? Am I correct in saying that there are only 2 ignition points on the ECU harness? The second problem I have is that the car will start up and then immediately cut out, can anyone tell me what the problem might be? Everything is fine once I remove the Emanage.
BTW - my car is a 1997 Mk1 1.8.
