Can anyone confirm that I have the correct connections?
I havent fitted the supra injectors yet, but will check for a spark.have you checked to see if you're getting spark? and checked to see if you are getting/can smell fuel? that would help narrow things down ie if you're getting spark then look at the inector wiring, or CAS wire.
you said you had uprated injectors? are they high impedance (like the 320cc Supra green tops) or low impedance (like the yellow tops)? if they're low impedance you'll need resistors to get them to work with the emanage blue.
afaik the inectors are wired in pairs at the ecu on my 1.6, but I'm miles away from the car and all my info so can't confirm that for you.
