1 - 6 of 6 Posts
Can someone tell me where ALL of these are and beat ways to unblock them
This is an how to on how to reconnect the drainage tube to the drainage try, http://www.mazdamenders.net/index.php/faqs-a-how-to/100-maintenance/120-drain-tube-replacing.html but it is the same for rodding to clear them, same place both sides, just be careful not to dislodge the tube while rodding.
There are also drainage points on either side of all the jacking points front and back ,rised dimples are the points that you need to get a small screw driver or simular to clear the holes.
M-m
Inside door seals, only info I can find is on the ones on the parcel shelf
1 - 6 of 6 Posts
