1 - 2 of 2 Posts
I'm on point 11
"Install the Q7 and U5 using the included heat sinks. Apply a dab of the included heat sink compound between the components and their heat sinks. Take care that the heatsinks do not touch together."
do you use 2 machine screws and the small nuts to secure the heatsink + FET/regulator in place ?
Like this . Then bend the legs, thin smear of heatsink goo and reassemble & solder.
Steve
Looks good. You should be able to see where you want to bend the legs from there then like you say - reassemble then solder in place.
1 - 2 of 2 Posts
