Ok here's how it goes. My 1992 Eunos Roadster has been in storage past couple months. I've recently got it MOT'd and it's been back on the road the past couple weeks. All good.
Last Wednesday I returned home from a 40 mile journey and started to notice a strong fuel smell. Popped the bonnet and found one of the injectors was leaking. A perished o-ring being the culprit. Replaced the o-ring and put everything back together. This is where it starts to get weird.
Tried to start the car - there was a strange banging noise and it tried to start then stalled.
Tried again - nothing. Symptoms of a flat battery. Jumped the battery from another car - nothing. On each turn of the key you could hear the starter motor trying to engage and then after you turned the key back a buzzer would sound. I've never ever heard this buzzer before!! And I don't have a buzzer for seat belt / lights / etc.
I then disconnected the battery (as I understands it resets ECU / erases fault codes?) Anyway, start the car and it fires straight into life.
HOWEVER
It also now produces the most horrendous 'death rattle'!! A really bad, loud knocking noise.
Took the cam cover off - belt is fine as are cam shafts.
No idea what has happened, maybe it's just coincidental and something has let go inside??
What I need to know is, would something terminal be evident when you crank the engine over without starting it?
I.E. I've taken the HT leads off - turned over the engine - NO NOISE.
I would of thought that if something has gone it would still show up this way?
Any ideas??
Thank you.
HOWEVER
Any ideas??
Thank you.
