Hi there,
I have not done this on my 5 but on my Volvo and it is a piece of cake...!!
1. Drop the coolant
2. Leave the drain plug open, stick the hose pipe in the radiator and let some water circulate through the system that way.
3. Do up the drain plug, fill the system with plain water, run the car until it starts to warm up, kill the engine and then drain the system again. Remember it will be hot water that is going to be coming out so it will burn!!
4. Do this a couple of times until the water runs clear if needs be.
5. Refil the system with the correct level and mixure of water/coolant.
Others may well have used a different method, however this did the job for me.
GOM
1. Drop the coolant
GOM
