1 - 8 of 8 Posts
Hi guys just changed my front brake discs and pads on my mk1 mx5.under slight braking there is a slight clunk before you come to a stop? didnt do it before,i greased the slidders up etc and thought everything was working as it should.
Cheers Adam
Offset stripes FTW!!!11
did you replace the shim plates behind the pads and the springs?
i bought mintex discs and pads and did not come with the shim plates but the ones i replaced never had them and never made a noise. weird. They never came with the springs either does that make a big difference?
The springs help to keep the pads off the disc. You can buy spring kits from MX5parts.
My rear brakes used to clonk like I had a stack of plates in the boot. Silent since fitting the springs.
What was the outcome of this??
I've had a clunk from my brakes since fitting new disks and pads, I have the springs but there weren't any shims on the old pads.
Autolink want ?2 per shim
1 - 8 of 8 Posts
