1.8 engine, loom and ECU perhaps?
cambelt & tensioner / idler rollers, waterpump, plugleads & sparkplugs, oil & oilfilter and airfilter.I have like 270 dollars left for power mods.
Nah just throw one in. £20 belt if you're super worried. Don't need to drain oil and can reuse coolant 😜cambelt & tensioner / idler rollers, waterpump, plugleads & sparkplugs, oil & oilfilter and airfilter.
that'll probably eat your $270 BUT anything left I'd look at getting the flywheel lightened - a worthwhile 'mod'
a good 1.6L driven hard is a capable car
$90 for what is effectively a bit of angle bar?? Are people really buying that rubbish, if so I can offer a similar product for £50 😆 😆 😆spend a few euros on some aluminium brackets and M6 nuts/bolts and boost your cooling with some mods to the undertray
Nielex claims a 5c lower temperature under bonnet and also perhaps in the engine...
Nielex Undercover End Lip For Miata MX-5 | REV9
Created for all NA and NB Miata models, the Nielex Exterior End Lip protects and improves the rigidity of the rear end of the lower engine room. It also prevents air from being sucked into the engine room, lowers engine temperature and protects the engine room from wear and tear. Installation...rev9autosport.com
Have you tried one of these? Or anyone by chance?spend a few euros on some aluminium brackets and M6 nuts/bolts and boost your cooling with some mods to the undertray
MUHH JAY DEE EMMSduct-tape & thin plastic or rubber sheeting (~1mm thick) to seal the underbonnet area between rad / subframe / chassis and maybe thin aluminium angle to brace the rad / bumper ducting should help matters (& cost a fair bit less)
although @atlex does like to buy overpriced things on the offchance they've a japaneeze sounding name (or someone from Japan had walked past them in a previous life![]()
You've earned yourself a new follower atlex!MUHH JAY DEE EMMS
actually I went full LEROY MERLIN (B&Q in Spain) on this..
http://instagr.am/p/Csqr9KbskTT/
Bit suss to me. I get the OE ones do flex a lot with uprated ARBs, but I cant see that wedging in of material is guna help much. I'd worry about them rubbing as well. Proper reinforced metal ARB mounts mounted to the chassis properly with a welder or larger bolts on the other hand would likely be worth it. Trouble is you reinforce one area to with stand more stress and generally you just move that stress elsewhere, so some consideration is needed as to where that might be and if it can take it.You've earned yourself a new follower atlex!
On the topic of strange cheap DIY mods with claimed benefits has anyone tried reinforcement brackets for their ARB mounts?
Miata Swaybar Reinforcement Bracket by the.cheat | Download free STL model | Printables.com
just not sure the ECU can use it. maybe it can ?Surprised nobody has suggested here swapping the cams for ones out of an early 115hp 1.6. Won't get you all the extra power but there's got to be about 15hp on the table. Definitely better bang for buck than things like air filters.
