1 - 3 of 3 Posts
has anyone done it ???
Well, I took one apart and put it back together again. I considered swapping the internals from one to another but in the end I just put the original differential back.
I got an 8" micrometer and a dial indicator from eBay and followed the guide in the miata.net garage section: http://www.miata.net/garage/diff_rr.html
You'll notice that the guide doesn't show how to do the hardest part - set up the pinion gear in a diff case. So if you intend to DIY I'd suggest you leave the pinion in its original carrier and fit the diff core of your choice into its ring gear.
thanks mate that a bit more trouble than i can be bothered with
1 - 3 of 3 Posts
