1 - 11 of 11 Posts
Does anyone know the cam cap torque specs? I have googled it but it only comes up with cam cover torque specs.
I need the torque specs for the cam caps that hold the cam in place.
It's actually a bit tricky as your working against springs. Stage one is getting everything in place. The torque required I dunno, but will be the minimum to get everything in possition. Then you might want to turn the cams a tad, back n forth, to be sure of alignment while the caps have a chance of moving still.
Now your back to a normal 3 stage job. 30% 60% 100% (you may find 30% is already done in this procedure) All done in sequence.
1 - 11 of 11 Posts
