1 - 9 of 9 Posts
The adjusters are on the rear brakes.
It might be your rear right caliper not moving propperly. Have a look at the disc's surface. No need to check the rear side, it's the front face that shows caliper slide problems.
It's pulling to the left at the front so will the rears affect this?
Well if your sure it's the front... But dropping an ancor from the rear passenger tie down would cause the car to crab left, thus drive left.
It's the same effect with the brakes. If the passenger rear works but the drivers is weak, the car want's to go left
Check the front offside brake as mine was doing this last year, it'll more than likely be either stuck with the pads binding or the slider pins need a clean and grease (do not use copper grease!!),
A new piston and sill kit will also help.
1 - 9 of 9 Posts
