1 - 3 of 3 Posts
Hi, just wondering how the brake booster is affected by boost? It feels like there is a lump/valve? In the tube from the mani to the servo, presumably to hold vacume. Does this stop the servo seeing boost when on throttle? Or do I need to fit a different valve? Thanks!
Also, I was keeping the charcoal canister of possible. Anyone kept it on a FI car? I'm guessing a valve may be needed here too?
(the car is a year 2000, td04, nearly complete!)
(I have got the mazda 323 pcv installed BTW)
Any advice much appreciated as can't find much info on the above topics.
馃榾
should be fine if you've the standard one-way valve in it's vacuum pipe馃槈
It feels like there is a lump/valve? In the tube from the mani to the servo, presumably to hold vacuum
as above, the standard one-way valve in it's vacuum pipe (y)
if it's working correctly:unsure:
as to the charcoal canister, if it's plumbed with the solenoid between canister & manifold then should be fine (presuming the solenoid is in good condition & seals properly:cautious:)
Thanks for the fast reply 馃憤
That's all handy to know 馃榾
I will check how my cannister is setup in a mo just to be sure 馃槵
Thanks again 馃榿馃檪馃憣
1 - 3 of 3 Posts
