Best Oil
15K views 77 replies 32 participants last post by  oilman
hi guys im looking into buying some oil for the mx5 and was just wondering what you would recommend?
i been looking on www.opieoils.co.uk and they recommend either a 5w-30 or a 5w-40 fully synthetic
just wondering what you guys run and weather i should get a fully or a semi oil?
cheers Dom
#12 ·
Well i changed my oil just a few weeks ago and used the UNIPART fully Synthetic 5w30 and it is reallly really nice oil its actually FUCHS super rebranded and was only ?17.99 engine revs lovely. I prefer to Mobil 1.
I have tried most oils but will stick to this one the engine seems to love it
#16 ·
10-60 edge in mine. its a greddy turbo, where oil is the only cooling the turbo gets.
5w-30 is listed on 5parts, but rightly points out its for the mk3 only. 30 is just too thin. All the manufacturers of oil will tell you that.
is the mk3 a ford lump? so carries over the ford spec oil from family use to sports. oops...
#17 ·
The 5-30 is too thin sometimes, but the 10w-60 is too thick, 5w-40 or 10w-50 depending on the oil temps are better choices as they will flow faster and help take the heat away
#24 ·
Well... Its not so a bad choice of words from us earlier really. On the older engines that may have more wear you could get higher consumption with an SAE30 over a SAE40 and perhaps an SAE30 may be more noisy but other then that no problem.
Guy
#26 ·
It's what I've put into my Roadster for the past two changes and I also slung it into my dad's when I serviced his NB8 last month. Worth checking what Opie oils are selling it for at the moment, IIRC it was at a very similar price although Opie do sometimes have cheap delivery deals on and the like so worth looking there before buying on the 'bay.
#28 ·
So how much do need for a complete oil service?
