1 - 11 of 11 Posts
Cheers dude!
I did wana see what what they looked like on a standard eunos roadster. Am i right in thinking the wheels are 6j with et40 offset?
They do look good. Did you go from standard 14s to those? if so did you notice a difference in acceleration and handling?
Before that I was using aftermarket 15s which come with the car.
Those were quite very heavy, up to 10kg each one, while the sport wheels only weight 5,9kg each. I noticed a HUGE difference, both on acceleration and handling.
Sounds good buddy! Are you running standard ride height?
Nope,
First picture, taken during a trackday in Brands Hatch i was running OEM springs with Koni Yellow Shocks, so it gives something like a 1cm drop.
Second picture, with my current setup, Mk2 AGX Schocks with matching Flyin Miata springs & mk2 top hats, I've measured i have 12.75" ride height on the front and 13.25" on the rear (measured from the center of the wheel to the fender lip).
1 - 11 of 11 Posts
