1 - 3 of 3 Posts
I was wondering if you could mount the sensor on the down pipe where the original sensor is? Also could someone advise which wire on the megasquirt I splice the white wire into? I take it I don't need the blue serial wire?
The futher from the manifold, the better. Mine is located just before the cat - i'm turbo'd and i have a Begi downpipe which has a bung just before the cat. O2 sensors don't like too much heat. Stock O2 location is OK but not ideal.
What is the white wire for? I can't remember offhand but for MS2 the O2 sensor is pin 23.
Thanks for that
The white wire is the one that sends the details to the ecu so must go to pin 23 if that's for the O2 sensor
1 - 3 of 3 Posts
