1 - 7 of 7 Posts
my cars tach gauge has not worked since i got it. after much searching of the internet i concluded it was dues to me having a 3 pin coil pack on it and it needs a 4 pin for the tach feed.
however having just looked at the coil packs on auto link it says my M reg should have a 3 pin like it already has.
is this correct?
Yeah, the transition from 4-pin to 3-pin was mid-1995, but it's not impossible for your M-reg to be a late registered 'series 1' 1.8.
Is it a UK car or a Roadster? If it's a Roadster, the infill colour on the rear "Roadster" badge is red on Series 1 cars (4-pin) and green on Series 2 (3-pin).
<edit> Wait a minute - M-reg is August 1994 to July 1995, isn't it? In that case the transition is when M-reg changed to N-reg, and your M-reg should be a 4-pin.
cheers for the help martin
its a uk car
on my log book it says the date of first registration is 25/02/1995
i dont have any badges on mine so i cant check them
is there any other way to make sure?
I'm not sure how to check on a UK car, perhaps someone else can chip in, but February '95 is before the changeover date. I don't think the 3-pin version was on sale by then.
There were other changes which came in that year - the change from a real oil pressure gauge (with a numbered scale) to a dummy gauge which just sits about halfway if there's pressure, but I don't know for certain if that came in at exactly the same time.
How many wires go into the back of the coil plugs? Surely there will only be 3 if it's meant to have 3 pin coils?
that makes alot of sense mclovin.
4 wires go into the top if the plugs but theres only 3 pins on the coil packs so 1 wire goes to nothing.
The 4th wire is likely to be the tacho signal. I have a set of 4 pin coils for sale if you're interested or now would be a good time to swap to Toyota COPS if you plan modding your car a bit.
1 - 7 of 7 Posts
