1 - 3 of 3 Posts
when I turn on the headlights the pop-up headlights elevate very promptly and the lights come on , as does the blue light on the dash .
But I am unable to turn the blue main beam off ( normally pushing / pulling the column switch does this )
1 ) Is there a relay that might be responsible for this fault ?
2) Could you tell me how to dis-assemble the steering cowling to get at the combination switch to see if a connection has come loose and can be tightened ?
3) Any other suggestions please ?
Thank you in advance
removing the column shroud is just a few screws unless someone's been there with glue 馃槻
the stalks / combination switch can fail (I have one that is jeffed) - removal involves the shroud and steeringwheel to come off then a clamp loosened before sliding it from the column.
the stalks can be dismantled, I've not done this yet but its on my list...
^^ headlight relay stuff
^^ headlight wiring diagram (might have different colours but should give an idea....)
Rich. (not awake yet & halfway through first coffeeo_O)
1 - 3 of 3 Posts
