So I decided to head back to the dyno, with the following changes from the last dyno:
- fresh oil/filter (5w40)
- fresh Spark plugs (modified earth electrode and indexed)
- shell V-power nitro fuel (99ron / 93oct)
- repaired the throttle cable!
So we strapped the car down, did a quick power run to see if we still matched power wise, it came back at 167bhp..... after reviewing the chart we realised we were really rich AFR throughout the range, this is when we realised the throttle plates we only opening 65-70%!
So we repaired the throttle cable (it must have stretched with use, needed to adjust my pedal stop!)
The car then pulled 201bhp on the same map, happy days - well within the last dyno results, I also adjusted the throttle linkage and I think we gained a bit more flow through the throttles because we had to add fuel throughout the range! Once this was sorted we started to play with cam timing.
The previous mapping session/dyno left the inlet cam 'straight up' which is as per the cam card but I had the exhaust cam retarded 2 degrees. So we put the exhaust cam back to 'straight up'
https://uploads.tapatalk-cdn.com/20180622/5810433b674e1108ad998afc3c4bfbc9.bmp
So the cams straight up made the power pretty well, although the torque curve past 6000rpm dropped very fast compared to the previous 198bhp dyno. The main plus with moving the exhaust cam back to straight up meant we gained some dynamic compression which helped the torque around 4000rpm by around 3-4ftlb, but as the car is fairly lightweight we didn't need it there!
So the next trial was to go the other way and retard the exhaust cam by 4 degrees (2more degrees than the 198bhp run).
https://uploads.tapatalk-cdn.com/20180622/c4194712825fbb74b3d87d3527374dee.bmp
As you can see the car didn't like that at all! Power down throughout the range, we suspected this was because we lost a significant amount of dynamic compression which would explain the lack of power everywhere!
So after a few more settings we trialed (with no reason to show the dyno chart) the best setting we found was inlet cam straight up and the exhaust cam retarded 1.5 degrees - this was the best balance between top end power and retaining the dynamic compression to improve torque.
So final results after optimising the AFR's (we ran slightly leaner at 12.7-13 AFR due to the better fuel giving us more confidence) and massaging the timing map, the results were in:
https://uploads.tapatalk-cdn.com/20180622/9a3ef88603708584480a5c3db3748f9e.bmp
211bhp / 172ftlb
As you could guess I am pretty excited about these results, mainly because the dyno used was the same with the same tyre pressures and correction factors so the additional changes/can timing changes gained 12-13bhp - well worth the faffing on the dyno!
I'll post the video of the 211bhp pull soon, we did see a highest reading of 216bhp but this was when the engine was allowed to cool off, 211bhp is the more accurate result as the engine was heat soaked by this point (back to back runs to prove output).
There's definitely no more to be had on this setup - we hit MBT in every cell at WOT, to prove this we advanced the timing by 2 degrees across the whole map just to see what would happen:
https://uploads.tapatalk-cdn.com/20180622/0762f16e792b08a1b37f41ba31106409.bmp
We never suffered any knock during the tuning, so this compression ratio and 99ron is good setup BUT the compression ratio was 'just' enough for these cams, this can be seen by the 4 degrees retarded dyno chart, just bleeding off a little bit more compression dropped power everywhere.
Driving the car is just fantastic, I love how the power holds to the redline stronger now.
Another cool thing is the power to weight ratio is approximately 350bhp/ton - it's great fun!
