Anyone Still On Here? - Newbies! Introduce yourselves here - MX5Nutz Forum
8 replies to this topic
#1 hooligan
hooligan
    internet warrior
  • 11621 posts
Posted 14 September 2020 - 08:37 PM
Popping back for the first time in years lol
Anyone still using this place?
#2 miles
miles
    Given up
  • Moderators
  • PipPipPipPipPipPipPipPipPipPipPipPip
  • 22534 posts
  • Gender:Not Telling
Posted 14 September 2020 - 08:59 PM
No
Posted ImagePosted Image
90 lil' Red Roadster M45, Konis, JR, RS*R, Watanabe,Torsen, Leather, ILM LoPros...............
98 RS Black Mazdaspeed shocks/springs, Autoexe CAI, RB Duals, gold wheels and Victory Lane air freshener ....
99 Sport red £700 of pure awesomeness.
#3 hooligan
hooligan
    internet warrior
  • 11621 posts
Posted 14 September 2020 - 09:45 PM
Excellent
#4 Martin Y
Martin Y
  • 10376 posts
Posted 14 September 2020 - 10:29 PM
Quiet as the grave.
But srsly there's been a bit more traffic around here the last couple of months.  Not like it once was, but not tumbleweed either.   And it's not Facebook, so there's that.
#5 Shadowraven
Shadowraven
  • 4506 posts
Posted 15 September 2020 - 10:07 AM
Yeh is rather quiet. All the info is sill here though and a few of the most knowledgeable members are still about which is all that really matters tbh.
I have noticed a few new people starting build threads recently though which is nice.
#6 Martin Y
Martin Y
  • 10376 posts
Posted 15 September 2020 - 11:46 AM
.... All the info is sill here though
It's also worth knowing that a quick bump can awaken broken zombie threads.
A lot of old threads didn't get revived properly after our Overlords accidentally crashed the forum in 2018, but if you find one that keeps reloading or only shows its first page you can usually awaken the whole thread by posting in it.
#7 hooligan
hooligan
    internet warrior
  • 11621 posts
Posted 15 September 2020 - 12:04 PM
Nice to browse old topics to be fair
I was prolific on here many years ago
Will pop in from time to time just to browse memories
#8 Andy-H
Andy-H
    was b0builder
  • 6496 posts
Posted 15 September 2020 - 09:09 PM
now thats a blast from the past
was it not you that had the black mk1 if you was i hate you, you cost me a fortune hhahaha
Black mk3 2.0 coupe (sneezy)
Ohlins
blink power package
superpro bushes all round
powder coated front and rear subframes
royal steering wheel
android head unit with isc 570 focal speakers
oz Alleggerita HLT with Michelin pilot 4's
#9 hooligan
hooligan
    internet warrior
  • 11621 posts
Posted 16 September 2020 - 07:22 AM
Yeah had a black mk1 for a long time ended up selling it to jimmy p
Currently drive a mk1 volvo c70 t5 coupe
330bhp of comfort lol
