Hsd Monopro Or Meisterr Zeta Crd - Wheels, Tyres, Suspension & handling/etc - MX5Nutz Forum
#coilovers #advice
6 replies to this topic
#1 eunosHarry
eunosHarry
  • 22 posts
Posted 01 August 2020 - 12:39 PM
Hi Guys, I haven't found a more up today discussion about this last one I found was around 5 years ago so i thought i should ask again
HSD monopro or Meister R zetaCRD
Price isn't really a problem there's a tenner or so in it
Car is a B road and some track use and a sort of daily but I don't use it to commute so it doesn't do long miles which would be suggested
I don't want to go super low as need to fit 15x8 with ad08r type tyres on it
I'm more swayed by Meister Rs but would like peoples suggestions
#2 Shadowraven
Shadowraven
  • 4414 posts
Posted 01 August 2020 - 03:55 PM
With those tyres you'd likely overwhelm the CRDs, so really you're look at clubrace or HSDs with the stiffer spring rate. I have a set or Clubrace and they are quite compliant, I have no issues using them on the road, that'd be my recommendation (no personal experience with HSDs though)
#3 Andy-H
Andy-H
    was b0builder
  • 6492 posts
Posted 01 August 2020 - 04:26 PM
i found hsd way to stiff and driftworks after sales support is a joke
i was smashing bump stop to pieces for fun (drifworks reply was we can sell you some more)
i was running superpro bushes and federal rsr tyres
changed to meisters and everything was peachy
yes it was on a mk1
Black mk3 2.0 coupe (sneezy)
Ohlins
blink power package
superpro bushes all round
powder coated front and rear subframes
royal steering wheel
android head unit with isc 570 focal speakers
oz Alleggerita HLT with Michelin pilot 4's
#4 eunosHarry
eunosHarry
  • 22 posts
Posted 01 August 2020 - 06:18 PM
yes it was on a mk1
I have read the bump stop stuff and the other stuff before which is what's swaying me towards meister R
#5 Shadowraven
Shadowraven
  • 4414 posts
Posted 01 August 2020 - 09:48 PM
I think
yes it was on a mk1
I think it's related to much less rear travel, meisters have more.
#6 Andy-H
Andy-H
    was b0builder
  • 6492 posts
Posted 01 August 2020 - 09:53 PM
indeed it was the hsd just didn't seam to have enough
Ohlins
blink power package
#7 Shadowraven
Shadowraven
  • 4414 posts
Posted 01 August 2020 - 10:21 PM
If you can justify the cost, I honestly would skip the CRDs and go straight to the Clubrace, they arent much more and I do feel the are a much more performance oriented option
