The racing debate is an interesting 1s as the size and tyre size is often regulated by the series. Im prob gonna try a 8j with a 205 slick next..
Posted 30 December 2020 - 10:23 AM
Posted 30 December 2020 - 11:49 AM
UKDM 1998 1.8 Mk2 Sport - Current mods- Custom 6 point chassis mounted front splitter and sideskirt extensions, battery cut off switch, OEM 'small skirts' and lip, HEL braided brake lines, OEM front upper strut brace with MC brace and mazdaspeed sticker, custom made 2" high flow catback exhaust, Japspeed 4-1 exhaust manifold, Lorber 15" alloys in fiat 750 maroon volcano, uniroyal rainsport2s, Ebay special JDMyo! gear knob, tinted indicators, colour coded reflectors, black headlight inserts, LED sidelights, SMD number plate bulbs, dimpled and grooved mtec brake discs, mintex brake pads, de-tango'd headlights, amber bulbs, RGB footwell lights, SMD interior light, Deltastyling spoiler, foamectomy seats, mazdaspeed seat belt pads, ring ultimax headlight bulbs, IL Motorsport style bar in custom paint, ford fan washer jets, Skidnation coolant reroute with Kia thermostat housing, Gates 22436 radiator hose with hose bracket, 82/85 degree twin valve thermostat, D1 spec engine bay dress bolts, stainless steel bolts throughout engine bay, EGR blanking kit, painted brake calipers, painted tow hooks front and rear, wrinkle painted cam cover, de-greened dials with white SMDs, red needles, painted cigarette lighter, painted oil filler cap, custom made cup holder, painted radiator retainers, polished slam panel, painted alternator, painted upper manifold, painted throttle body, painted header heat shield, painted relay bracket, painted loom brackets, painted diagnostics box bracket, painted wash fluid brackets, painted ABS brackets, painted airbox brackets, painted horns and brackets, painted throttle cable brackets, painted charcoal canister brackets and hard piping, painted wiper rods, painted engine hooks, painted clutch line bracket, Jass offset license plate bracket, offset square plate, 1lt foam fire extinguisher on custom bracket and custom Velcro retaining strap, POR15 rust proofed to within an inch of it's life, cavity waxed and fully seam sealed
UKDM 2001 mk2.5 - Current mods- SMD interior light, SMD number plate lights, Corbeau Sprint (yes it fits!), modified mk2.5 door card, Skidnation seat brackets, Corba 1046 remote central locking unit, Driftworks basics 350mm leather steering wheel, NRG short hub, NRG 2.5 quick release hub, 8" weighted gear knob, factory electric wing mirrors, factory electric aerial, Kage 4" exhaust with additional powerflow silencer, foam fire extinguisher, custom fire extinguisher mounting bracket, painted cam cover, painted oil filer cap, 15" Advan SA3Rs, Nankang NS-2R 180tw, offset plate bracket, RGB footwell lighting, sun strip, painted calipers and carriers, painted headlight inserts, softtop delete, brake fluid reservoir sock, GCR3 roll bar in custom gloss black, Corbeau Ultima Pro 2006SSU 6 point harness, push button bumper quick release pins, twin port oil catch can, engine bay respray, fully POR15 rust proofed chassis, full chassis seam seal, custom permanent hardtop side mounts, Jass permanent hardtop front mounts, M-tuned large rear rotor spacers with corresponding 276mm SVT brake discs, Freakyparts larger front rotor spacers with corresponding 11" Corado G60 front rotors, HEL braided brake lines, Byba Kits GV style front lip, SVT under chassis bracing, painted radiator brackets, mazdaspeed seat belt pads, charcoal canister delete, large Mazdaspeed side skirts, adapted NA short shifter, 60mm alloy radiator, 3" brake ducts, upper strut brace with MC brace, 3.9 type 2 torsen, 80A diff bushes, front tow hook, rear tow hook
2004 Celica T Sport - Current mods- Meister Zeta Pro coilovers, Forged Wilwood dynalite front calipers, Yellow stuff brake pads up front, Drimpled and slotted discs, Braided brake lines, TRD stubby aerial, Short shift kit, 17" alloys powdercoated in metallic granite, TRD centre caps, Invidia exhaust, Cusco brake master cylinder brace, SMD side light bulbs, butterfly valve delete, Aux to CD converter, 8" gear knob, sun strip, interior SMD bulb, remote damper adjusters
Posted 30 December 2020 - 11:53 AM
Posted 30 December 2020 - 12:25 PM
That's very kind of you, we are currently in tier 4 here and my car is currently SORN and has 2 sticking brake calipers I was unlikely to find the motivation to fix until the Spring but could likely try and sort something in a few weeks?
I also find the width vs heat thing a bit odd, Nankang recommend the tyres all the way down to cars below 800kg, just adjust the tyre pressures accordingly and drive harder if you are having trouble getting heat into them.
Posted 30 December 2020 - 06:14 PM
Posted 06 January 2021 - 01:26 PM
Posted 06 January 2021 - 10:08 PM
Sounds good, let me know how it goes. So the 215 section width on the 205s might not actually translate to a 215 wide contact patch, the section width is just the widest part of the tyre and that may not fall on the contact patch. It's why both section width and tyre size width are reported, and is useful as a guide for fitment.
I'd be interested to see how wide the contact patch is, I'd also like to measure my 195s (reported as 204 wide) to see what they really are.
Posted 06 January 2021 - 10:21 PM
Posted 07 January 2021 - 12:12 AM
the 225s are listed as having a 225 section width and tread width so that's to be expected.
Yeh pushing for more grip can never hurt, you can always make use of more grip and more brakes I say.
Posted 11 January 2021 - 08:34 PM
Posted 11 January 2021 - 08:39 PM
Posted 11 January 2021 - 11:27 PM
Hmmm, not super light wheels then, but not bad, and really cheap which is something you do want for a track wheel.
I might pull the trigger on the konigs, just waiting on part one of a brake upgrade which got lost in the post before christmas, and about to get massively side tracked with the other car. I am trying to get the distributer to knock the shipping off but so far no joy.
Posted 12 January 2021 - 10:48 AM
Posted 12 January 2021 - 10:52 AM
Posted 12 January 2021 - 11:50 AM
A weight saving is a weight saving, as long as they still grip, lol.
