Mx5 Head - Dropped A Stem Seal Into The Hole Between The Valves! - General Car Chat - MX5Nutz Forum
14 replies to this topic
#1 baker556
baker556
  • 419 posts
Posted 26 July 2020 - 05:29 PM
Hi guys,
I've been changing the mx5's stem seals over the last couple of days, finally on the last four and I dropped this one in between the two valves, when trying to retrieve this, it was unfortunately pushed in further into a hole.
From looking at pictures of mx5 heads online, I'm unclear is this hole actually does anything at all, originally thought it was the oil return, but appears to just do nothing.
I might have to leave the steam seal in there, there is a huge concern over doing this just wondering if anyone knows the exact location of the oil return holes.
The location is between to valves in the head, it appears with the head off that there is no hole for this to go any further.
Thoughts?
#2 Dickie
Dickie
  • 520 posts
Posted 29 July 2020 - 08:05 PM
Do not leave anything dropped inside the head.
There is always the possibility that the item can cause damage.
Which model and engine do you have ?
Most of the holes in the cam area are for oil drainage back to the sump.
Have you made a hook out of a wire coat hanger to try to remove the wandering seal ?
#3 dadbif
dadbif
  • 745 posts
Posted 29 July 2020 - 09:26 PM
Any pictures?
#4 albion1938
albion1938
  • 415 posts
Posted 30 July 2020 - 11:29 AM
Magnetic pick-up tool?
Bernard
#5 Ecosse
Ecosse
    Ecosse
  • 3859 posts
Posted 31 July 2020 - 08:49 AM
Bernard
Are they not (mostly) some sort of neoprene plastic?
I'm thinking as mentioned the wire coathanger, with maybe  blob of Tiger Seal or summat on the end of it..let it set, and...well...good luck.
Beware the imbecile you did not bargain for. Perhaps in a Zafira  at Tesco waiting to self combust.
#6 albion1938
albion1938
  • 415 posts
Posted 01 August 2020 - 10:30 AM
Bernard
A long time ago now I admit but when I worked at a Mazda dealer they were steel  with the rubber seal bonded on. If they've changed since I stand corrected and will get my coat!
Bernard
#7 McTrucky
McTrucky
  • 13 posts
Posted 01 August 2020 - 10:49 AM
Compressed air ? Maybe able to get a nozzle deep enough into the hole to blow it out?
#8 dadbif
dadbif
  • 745 posts
Posted 01 August 2020 - 08:56 PM
You need something hard and sharp with a barb, like a little harpoon
#9 Ecosse
Ecosse
    Ecosse
  • 3859 posts
Posted 02 August 2020 - 09:34 PM
My wife's tongue is available for a reasonable fee.
#10 R3k1355
R3k1355
  • 3528 posts
Posted 08 August 2020 - 01:07 PM
Pics needed
Bernard
There is some metal in them, a little wire collar around the top to hold it against the stem and the body has some kind of metal in it as well.
#11 baker556
baker556
  • 419 posts
Posted 06 September 2020 - 03:16 PM
Hi all,
Thanks for the replied, I left this for sometime and tried lots of way to fish this out without any luck.
I do think the engine has had it anyway, so I'm not overly concerned tbh, although saying this after everything was put back together there was a loud concerning knocking noise, it doesn't matter as this didn't fix the underlying issue of oil control rings.
But for everyone here is a nice video of I think the bottom end getting chewed up, correct me if I'm wrong. This is after having the cams out and replacing the valve stem seals - it could well be something else, maybe timing is not correctly set or where the car hasn't been turned on in 3 months oil starvation, who knows.
#12 Jim A
Jim A
  • 55 posts
Posted 07 September 2020 - 02:38 PM
:lol:
#13 R3k1355
R3k1355
  • 3528 posts
Posted 27 September 2020 - 07:54 PM
Hi all,
Sure it's not just the lifters?
Can be all out of oil if you've removed them.
#14 atlex
atlex
  • 1489 posts
Posted 28 September 2020 - 10:19 AM
clean and refill the lifters (LOADS of guides on youtube), get the missing piece out.
#15 dadbif
dadbif
  • 745 posts
Posted 28 September 2020 - 12:35 PM
Definitely hydraulic tappets, either put some cheap clean oil in with a fresh filter and give it a thrash or as suggested clean them out...
