Read this: Trading and advertising on the forum - Conditions and how to enquire
5 Speed Turret In 6 Speed
#1
Posted 05 January 2021 - 01:30 PM
Cheers!
#2
Posted 05 January 2021 - 01:40 PM
Sent from my Nokia 6.1 using Tapatalk
#3
Posted 05 January 2021 - 01:48 PM
#4
Posted 05 January 2021 - 01:55 PM
#5
Posted 05 January 2021 - 02:59 PM
#6
Posted 06 January 2021 - 10:03 PM
All 6 speeds and later 5 speeds have 2 prongs in the turret, early 5 speeds had 1. There are 2 versions of the 6 speed that have different ball/cup diameters, from 2003 onwards they are larger, they are not interchangeable. Later 6 speeds have a slightly longer throw than the earlier 6 speeds as well due to the pivot point to cup being further apart, and both 6 speeds have a different pivot point to cup length than the 5 speeds. However I do not know whether the early 6 speed shifters and later 5 speeds are interchangeable, I imagine the answer is no as the pivot point to cup distances are different, but a quick test off the car of a 5 speed short shifter worked fine in my early 6 speed but I havent had a chance to install the 6 speed and actually try it on the car (and it's an aftermarket not OE shifter so not directly comparable I guess).
UKDM 1998 1.8 Mk2 Sport - Current mods- Custom 6 point chassis mounted front splitter and sideskirt extensions, battery cut off switch, OEM 'small skirts' and lip, HEL braided brake lines, OEM front upper strut brace with MC brace and mazdaspeed sticker, custom made 2" high flow catback exhaust, Japspeed 4-1 exhaust manifold, Lorber 15" alloys in fiat 750 maroon volcano, uniroyal rainsport2s, Ebay special JDMyo! gear knob, tinted indicators, colour coded reflectors, black headlight inserts, LED sidelights, SMD number plate bulbs, dimpled and grooved mtec brake discs, mintex brake pads, de-tango'd headlights, amber bulbs, RGB footwell lights, SMD interior light, Deltastyling spoiler, foamectomy seats, mazdaspeed seat belt pads, ring ultimax headlight bulbs, IL Motorsport style bar in custom paint, ford fan washer jets, Skidnation coolant reroute with Kia thermostat housing, Gates 22436 radiator hose with hose bracket, 82/85 degree twin valve thermostat, D1 spec engine bay dress bolts, stainless steel bolts throughout engine bay, EGR blanking kit, painted brake calipers, painted tow hooks front and rear, wrinkle painted cam cover, de-greened dials with white SMDs, red needles, painted cigarette lighter, painted oil filler cap, custom made cup holder, painted radiator retainers, polished slam panel, painted alternator, painted upper manifold, painted throttle body, painted header heat shield, painted relay bracket, painted loom brackets, painted diagnostics box bracket, painted wash fluid brackets, painted ABS brackets, painted airbox brackets, painted horns and brackets, painted throttle cable brackets, painted charcoal canister brackets and hard piping, painted wiper rods, painted engine hooks, painted clutch line bracket, Jass offset license plate bracket, offset square plate, 1lt foam fire extinguisher on custom bracket and custom Velcro retaining strap, POR15 rust proofed to within an inch of it's life, cavity waxed and fully seam sealed
UKDM 2001 mk2.5 - Current mods- SMD interior light, SMD number plate lights, Corbeau Sprint (yes it fits!), modified mk2.5 door card, Skidnation seat brackets, Corba 1046 remote central locking unit, Driftworks basics 350mm leather steering wheel, NRG short hub, NRG 2.5 quick release hub, 8" weighted gear knob, factory electric wing mirrors, factory electric aerial, Kage 4" exhaust with additional powerflow silencer, foam fire extinguisher, custom fire extinguisher mounting bracket, painted cam cover, painted oil filer cap, 15" Advan SA3Rs, Nankang NS-2R 180tw, offset plate bracket, RGB footwell lighting, sun strip, painted calipers and carriers, painted headlight inserts, softtop delete, brake fluid reservoir sock, GCR3 roll bar in custom gloss black, Corbeau Ultima Pro 2006SSU 6 point harness, push button bumper quick release pins, twin port oil catch can, engine bay respray, fully POR15 rust proofed chassis, full chassis seam seal, custom permanent hardtop side mounts, Jass permanent hardtop front mounts, M-tuned large rear rotor spacers with corresponding 276mm SVT brake discs, Freakyparts larger front rotor spacers with corresponding 11" Corado G60 front rotors, HEL braided brake lines, Byba Kits GV style front lip, SVT under chassis bracing, painted radiator brackets, mazdaspeed seat belt pads, charcoal canister delete, large Mazdaspeed side skirts, adapted NA short shifter, 60mm alloy radiator, 3" brake ducts, upper strut brace with MC brace, 3.9 type 2 torsen, 80A diff bushes, front tow hook, rear tow hook
2004 Celica T Sport - Current mods- Meister Zeta Pro coilovers, Forged Wilwood dynalite front calipers, Yellow stuff brake pads up front, Drimpled and slotted discs, Braided brake lines, TRD stubby aerial, Short shift kit, 17" alloys powdercoated in metallic granite, TRD centre caps, Invidia exhaust, Cusco brake master cylinder brace, SMD side light bulbs, butterfly valve delete, Aux to CD converter, 8" gear knob, sun strip, interior SMD bulb, remote damper adjusters
#7
Posted 07 January 2021 - 10:30 AM
#8
Posted 07 January 2021 - 11:08 AM
5 speed gearstick in a 6 speed = ghetto quickshift
although theres only a small difference in the ratio's between so not a great ammount shorter throw.
50 Shades of Silver. '91 NA6CE, Not a show car
Ohlins dampers, goin drysump, EPS, 4.778:1 & more ideas than time
Bodger
#9
Posted 07 January 2021 - 03:04 PM
Lol, you're statement has more relevance to me than you intended. Mk1 short shifters can be had for £20 on ebay, mk2 ones are like £160. I was fed up of punching my radio on track so set about looking at the differences and found that it's literally just the turret spacer, so bought a mk1 kit and cut an extra slit to fit into the mk2 gearbox (knocking the pin out is strongly advised against by a number of reputable mx5 shops so didnt want to do that). It works perfectly fine. However, I am due to move to a 6 speed box as the 5 speed ratios are trash for track work on a stock power car IMO and have been trying to work out how best to do it and which shifter is most compatible with the kit I have put together (I have both a later and early 6 speed box, they were under £200 so rude not to). Maintaining the pivot point seems to be the most important, but the non-OE nylon/metal cups appear to be deeper and shaped differently so it might not matter as much as I originally thought.
#10
Posted 07 January 2021 - 06:17 PM
ha.
I played with the oem bits for a while then said buggerit & made my own gearstick
obviously I'm expecting it to break..........
Bodger
#11
Posted 07 January 2021 - 08:10 PM
