Konig Dial In Dealers - General Car Chat - MX5Nutz Forum
34 replies to this topic
#1 Shadowraven
Shadowraven
  • 4569 posts
Posted 27 December 2020 - 01:02 PM
I'm after a set of Kongi Dial In's (grey, 15x8, et25) but cant seem to find anywhere to buy them from. Does anyone have any ideas. Racingbeat offer them for £1000, which is ridiculous, even after accounting for shipping and tax it's very high, especially as they are currently on offer in the states for £400 a set!! . I can't seem to find them in grey from the only two UK distributors Konig list.
#2 boosted
boosted
  • 1877 posts
Posted 27 December 2020 - 01:55 PM
I too have been looking for a set of 8j/8.5j lightweight alloys and the konig came up but i want et0...they are very expensive. Next time i speak to Clive ill ask the question. I wish i weighed the japan racing jr12s and ar1s seperately now..combined 16.6kg seems pretty heavy to me...unsprung weight etc etc.
#3 Shadowraven
Shadowraven
  • 4569 posts
Posted 27 December 2020 - 03:57 PM
AR1s are really heavy tyres, Nankang do list all the weights of their tyres so you can work out how heavy the JR12s were.
Brake clearance is a big point for me, my only development plans for the track car next season are to get it on some 225s and up the brakes to the wilwood midlite kit, so I need a wheel that'll clear them, the konigs seem to do that well, offer a good amount of strength, look pretty track orientated and are light. They are very good value at the US prices, but at £1000, pretty hard to justify in the UK.
#4 boosted
boosted
  • 1877 posts
Posted 27 December 2020 - 04:47 PM
Cheers ill do some hunting and get a weight of the jr12s.
Smart phonesdont work with crusty filler on yr fingers! Lol489906cd4af926af74ea368fac1a3315.jpg
#5 boosted
boosted
  • 1877 posts
Posted 27 December 2020 - 05:06 PM
Ar1s 225 45 15..10.34kg..
That means the 8.5j 15" ar1s are 6.3kg....2.8lbs heavier than 8j konigs...mmmm. lot of money to save a tiny bit of weight...im very happy with my jr12s...now lole9a8247f9c05dde0eb208f76512b2348.jpgee77a75c8d8d796a3d5f2ca2deda7b78.jpg
#6 Shadowraven
Shadowraven
  • 4569 posts
Posted 27 December 2020 - 07:39 PM
Konigs are 5kg each in 15x8 apparently, and for me they are quite a bit lighter than my 7ish kg SA3Rs I currently have. I will also need the brake clearance
#7 boosted
boosted
  • 1877 posts
Posted 27 December 2020 - 07:43 PM
Its a frikin light wheel!
#8 boosted
boosted
  • 1877 posts
Posted 29 December 2020 - 10:33 AM
Following on ive been looking at slicks..smaller width tyre but more or same grio..i couldnt believe how light my 13" team dynamic wheels with a005 slicks were compare to the 15" TD shod with r888r.
Basically by having a normal wheel and slick saves more weight than an expensive lightweight wheel with a heavy wide semislick. If i swap out to Ultralight ul11s 8j et0 and an rs1 slick im saving a few kgs...ive asked the weight of the ul11s...ce94f3a5ac402913f234c1a3e4d73ce2.jpg
#9 boosted
boosted
  • 1877 posts
Posted 29 December 2020 - 10:37 AM
UL11s...these should be lighter than the wider jr12s and massive saving on tyre weight...BUT..is the 205 slick gonna be same or better grip than 225 ar1s...expensive ? to find out. The rs1s are a tenner more than the ar1s...at £150 ea. Mmmmm.
Driving on slicks is awesome everything is better..braking turning grip everywhere...
#10 Shadowraven
Shadowraven
  • 4569 posts
Posted 29 December 2020 - 01:15 PM
It's all a trade off, smaller is lighter, but will they clear the brakes? Will slicks in that size give the same grip as 225s? Will it be as easy / cheap to get tyres? Will having slicks limit you being able to use the car at the weekends? Lots to consider really.
#11 noobie
noobie
  • 857 posts
Posted 29 December 2020 - 01:36 PM
225 AR-1s on 8J rims will be nothing special, 205 AR-1's might even be quicker (run quite wide). 205 slicks will be seconds a lap quicker.
#12 boosted
boosted
  • 1877 posts
Posted 29 December 2020 - 01:38 PM
Yeah slicks arent manufactured to same constraints as e marked semis... if just for track...then cheaper wheels with 205 slicks...
Food for thought.
#13 Shadowraven
Shadowraven
  • 4569 posts
Posted 29 December 2020 - 06:27 PM
Not sure how that works? I know a 225 is quicker on a 9j than an 8j due to how the extra width helps the tyre wall resist flexing more, but can't see why a 205 on an 8 would be faster than a 225? Surely more tyre will also go e more grip. I know some say they prefer having a slightly narrower tyre so the car moves about a bit more but Iv never seen any proof it's faster, just a preference thing. Regardless, vs my current setup of sa3r and ns2r, a 225 ar1 and 15x8 dial in would save just shy of 1.5kg per corner and give me 30mm more tyre in a much gripper compound, and clearance for a better brake setup so I can't really see the downside for me? I can't run slicks as I need the car to be road legal
#14 boosted
boosted
  • 1877 posts
Posted 29 December 2020 - 06:53 PM
Ive found the 225 45 15 ar1s...on 8.5J to be pretty much awesome..the nearest semi slick to slick like grip ive experienced. My car at Bedford on them was great...pretty much overtook everything that day...it was planted.
#15 noobie
noobie
  • 857 posts
Posted 29 December 2020 - 08:43 PM
Not sure how that works? Surely more tyre will also go e more grip.
More weight, more drag, suboptimal use of available contact patch. etc. That and the 205 AR-1 being a 215, so the 8J rim is perfect for it.
#16 atlex
atlex
    Hiding from the Ayatollah or making Full Metal Jacket.
  • 1509 posts
Posted 29 December 2020 - 09:07 PM
If you really want them get them from the states. heh.
#17 Shadowraven
Shadowraven
  • 4569 posts
Posted 29 December 2020 - 10:14 PM
Optimal use of contact patch is down to how it's used, ie what I said about 15x8 vs 15x9. If the 225 has more patch it'll generate more grip. I'd also imagine the drag penalty would be very minor and more than offset by the extra cornering speed.
I was just after info about UK dealers. Sadly the ultralite aren't available in the right offset, but are worth looking into for my celica in future maybe so cheers for that.
#18 Andy-H
Andy-H
    was b0builder
  • 6500 posts
Posted 29 December 2020 - 10:36 PM
i remember when i got my oz ultraleggera hlt's when i picked them up i thought the box was empty lol
when i swap to the winter ones oz wrc the weight difference is incredible
i cant remember the weights but i seam to remember the wrc with snow tyres being nearly double (don't quote me on that)
Black mk3 2.0 coupe (sneezy)
Ohlins
blink power package
superpro bushes all round
powder coated front and rear subframes
royal steering wheel
android head unit with isc 570 focal speakers
oz Alleggerita HLT with Michelin pilot 4's
#19 MR Wallace
MR Wallace
  • 415 posts
Posted 30 December 2020 - 09:32 AM
Optimal use of the contact patch includes how much weight/ force is put into that area. Bigger isn't always better, if there isn't enough load on the tyre you won't generate any extra grip. On a standard-ish MX5 with no real aero I would think a 225 is definitely overkill and won't generate enough heat to give more grip than a 205.
If you look at mx5's that compete in the 750mc you'll find they only use 205 or 195 tyres and other cars (clios) that are a similar weight in time attack are the same.
I'm going back down to a 195 for sprints/Hill climbs as I don't feel I can get heat into a 205 quick enough to gain any benefit over the extra weight, drag and gearing change.
#20 Zed.
Zed.
  • 1843 posts
Posted 30 December 2020 - 09:40 AM
less is more ;)
although it don't look as fast :popcorn:
Bodger :ph34r:
