Mk1 Engine Swap - MX-5 / Roadster Forum - MX5Nutz Forum
Mk1 Engine Swap
29 replies to this topic
#1 jcm32517
jcm32517
    One post wonder
  • 7 posts
Posted 18 November 2020 - 08:43 AM
Hi
First post so apologies if its in the wrong section.
I have a 1993 mk1 1.6 longnose crank which needs a new engine due to the woodruff key being absolutely mullered by someone previous
My question is which engine swap should I do? More power obviously!! Is there a definite list of which engines fit which models?
I have searched but the information is confusing and I'd like the easiest swap possible utilising my wiring, ecu etc .
Any information greatly appreciated
John
A picture of the car as we all like pictures 41243bed8bc3425f04b9f62764ce4f15.jpg
Sent from my SM-G960F using Tapatalk
#2 Bol
Bol
  • 150 posts
Posted 18 November 2020 - 10:55 AM
Same answer as before. If you want to use everything you’ve already got, you need to do a straight swap. It’s then different for each of the other oem engines - but doable, particularly if you can get the ECU, loom etc from the donor.
#3 Zed.
Zed.
  • 1807 posts
Posted 18 November 2020 - 11:08 AM
just about anything will fit, whats your budget & mecanical / bodge level?
easy like-for-like is another 1.6, the 1.8 is popular (but needs a lot of ancillary parts as 1.6 & 1.8 engines are different lengths as a start!)
@carl s has a good writeup of his 1.6 - 1.8 swap (with photos :lol: )
https://www.mx5nutz....22586&p=4480193
obviously theres easier with the earlier mk1 1.8 engine as in FM's guide (you don't have to buy their stuff to convert...)
https://www.flyinmia..._conversion.php
or the posh version...
https://www.flyinmia...isc/1.8swap.pdf
add a supercharger or turbo?
then theres honda k20 or k24 4 cylinder, honda k30 v6, gm's LS v8 engines.............
Bodger :ph34r:
#4 Zed.
Zed.
  • 1807 posts
Posted 18 November 2020 - 06:22 PM
Ah, the Ignore function :lol:
again :rolleyes:
Bodger :ph34r:
#5 jcm32517
jcm32517
    One post wonder
  • 7 posts
Posted 18 November 2020 - 06:39 PM
Same answer as before?
I appreciate the easiest route is Same engine as I already have, is the 1.8 worth the hassle over the 1.6?
#6 Bol
Bol
  • 150 posts
Posted 18 November 2020 - 06:44 PM
Sorry, I miss read your post and thought I’d responded to you about it before.
I’m not sure I’d go to the hassle of swapping from 1.6 to 1.8 for the sake of 15 horses. Maybe for the vvt, but that’s even more complicated. I’d be inclined to go like for like then turbo or supercharge.
#7 jcm32517
jcm32517
    One post wonder
  • 7 posts
Posted 18 November 2020 - 06:45 PM
@carl s has a good writeup of his 1.6 - 1.8 swap (with photos )
Thanks for the info, the original plan was always to turbo the car, but I was trying to get everything tip top first!
The 1.8 swap seems a lot of hassle for 200cc and maybe 15-20 bhp ? I don't think its worth it..
My mechanical bodgery is ok , nuts and bolts no problem but diagnostics and the clever stuff not so much
#8 jcm32517
jcm32517
    One post wonder
  • 7 posts
Posted 18 November 2020 - 06:49 PM
No worries, confused me as well
I don't think the gain is enough for the 1.8 swap, as ever more power is not an easy gain... I think I'll just look for a decent 1.6 engine and throw that in.... then sort the turbo later..
I may try the loctite fix first and see if I can bodge it until I have more free time.
#9 Bol
Bol
  • 150 posts
Posted 18 November 2020 - 08:03 PM
The alternative is to get your bottom end rebuilt with new bearings and honed crank (if it needs it). Will be a similar cost all in and at least you’ll know you’ve got a decent engine. I got a low mileage used one when my woodruff key was fubared and ultimately regretted it. The new engine had a dodgy oil pump and I ended up having to rebuild the bottom end on that one. If I’d stuck with the original I’d have saved myself about a grand. Different story if you can fit it l yourself though. I can’t.
#10 Zed.
Zed.
  • 1807 posts
Posted 18 November 2020 - 08:30 PM
the bonus of a 1.8 conversion is 240cc & more torque, the ~15hp is minimal but the torque is aparently very noticeable :blink:
I'm staying with the 1.6 (for competition class reasons) but goin diggin&fiddlin for shitz&giggles :whistle:
but then I'm not doing the conventional mx5 'thing' either :wallbash:
Bodger :ph34r:
#11 Zed.
Zed.
  • 1807 posts
Posted 18 November 2020 - 08:34 PM
90 or 115 hp? :popcorn:
Bodger :ph34r:
#12 tony100
tony100
  • 89 posts
Posted 18 November 2020 - 08:49 PM
Surprising that a long nose crank keyway is going bad, is there 8 slots on the pulley?
#13 Zed.
Zed.
  • 1807 posts
Posted 18 November 2020 - 10:17 PM
Excellent question :yes:
they can fail if badly assembled, like everything its down to the mecanic or fitter....
Bodger :ph34r:
#14 jcm32517
jcm32517
    One post wonder
  • 7 posts
Posted 18 November 2020 - 10:22 PM
Yes 8 slots on the pulley, car and engine seem in fairly good order lots of history etc.. the engine has always struggled with power below 3k revs sluggish etc..
I was hoping the cambelt had been fitted incorrectly and a belt change would sort it..
Unfortunately the bottom was loctited in and the key way is definitely splayed, im yet to get the woodruff key out to see the full extent of the damage.
#15 jcm32517
jcm32517
    One post wonder
  • 7 posts
Posted 18 November 2020 - 10:23 PM
115 according to the vin plate but drives like a 90
#16 Zed.
Zed.
  • 1807 posts
Posted 18 November 2020 - 11:51 PM
before you condemn anything check the crank - cam timing, if both cams are out it can do horrible things....
Bodger :ph34r:
#17 tony100
tony100
  • 89 posts
Posted 19 November 2020 - 04:46 PM
Yeah thought I'd ask - it is interesting that quite a few of the non-short nose engines suffer with the issue.
I got a SNC engine and I abuse it regularly... Seems fine to me
#18 Zed.
Zed.
  • 1807 posts
Posted 19 November 2020 - 05:43 PM
20-something years of repairs can take their toll, the longnose (bignose) can suffer the same workmanship as the earlier shortnose although the earlier engine can seem to fail for fun...
interestingly the snc failures seem to be mostly something of legend now so either it was the rumored bad luck or machining tollerances that caused replaements as the suviving cranks seem to be reliable :blink:
I've a snc (lightwieght sports crank according to Mazda :) ) engine in my 1990 Eunos, the timing gear was stripped off when I bought it for waterpump replacement but the crankshaft was (is) in perfect condition B)
I also have another snc spare B)
the snc / lightwieght sports crank is exactly that, a bit lighter than a later longnose (bignose?) item so should be slightly quicker revving than a later item :blink:
now, I'm trying to get brave enough to build my drysumped engine around the lighter crank :whistle:
Bodger :ph34r:
#19 tony100
tony100
  • 89 posts
Posted 19 November 2020 - 05:53 PM
Yeh my front crank seal needed doing and the keyway looked mint. Not touched it since. No need.
I've wondered if there is an uprated bolt (arp?) That would fit the crank but I've not been able to figure that out yet. Nor of it's even worth doing.
#20 Zed.
Zed.
  • 1807 posts
Posted 19 November 2020 - 06:32 PM
one of the common bolting-failures seems to be around the crank splitting between the threads & the keyway, the thinnest section of the nose.
I'd happily use an Allen-bolt in place of the origonal Mazda item, cheaper than an ARP replacement?
Allen bolts are usually high-tensile and available in several rates above the average 8.8 grade with 10.1, 12.9 & 14.something if you'd need such?
Bodger :ph34r:
