Jb Fab Bucket Seat Mounts Don't Fit Passenger Side - Interior - MX5Nutz Forum
1 reply to this topic
#1 just_a_red_94
just_a_red_94
    One post wonder
  • 9 posts
Posted 19 November 2020 - 11:58 PM
Anyone fitted a pair of jb fab bucket seat side mounts into their car? Drivers side fit nice and snug but the passenger side is way too narrow for the mounts to fit in?
#2 Shadowraven
Shadowraven
  • 4818 posts
Posted 20 November 2020 - 11:25 AM
The seat bolt holes are slotted so should fit, I do hear they are a knightmare to fit, although my experience with other mounts on the drivers side has been the same. The passenger seat bolt points are narrower due to an asymmetrical trans tunnel.
