Number 23 Boosted Time. - Page 14 - Members Rides - MX5Nutz Forum - Page 14
264 replies to this topic
#261 dadbif
dadbif
  • 694 posts
Posted 12 August 2020 - 08:34 AM
Well done in the heat!
#262 boosted
boosted
  • 1524 posts
Posted 12 August 2020 - 08:42 AM
Im paying for it today...ache all over and sunburnt back lol.
#263 Shadowraven
Shadowraven
  • 4415 posts
Posted 12 August 2020 - 01:33 PM
I feel your pain. I swapped a diff Sunday/Monday and had a load of issues getting it out so took hours. At least there was some shade under the car  :D
#264 boosted
boosted
  • 1524 posts
Posted 12 August 2020 - 01:44 PM
Im getting slower n slower as the day goes on. Shouldve quit earlier yesterday but this cage job been dragging on.
My Diff job was ballache on a ramp with a collar ceased czn imagine absolute mare on driveway.
#265 Shadowraven
Shadowraven
  • 4415 posts
Posted 12 August 2020 - 08:04 PM
Seized collar is exactly what happened. The US guys make it look so easy, just pry it out with a screwdriver, lol. I had to drop the entire thing with the PPF attached and separate it off the car, which still wasnt and easy task.
