Stop A Mk1 Going Rusty? - How do I... - MX5Nutz Forum
6 replies to this topic
#1 stashio
stashio
  • 12 posts
Posted 10 September 2020 - 05:57 PM
I know probably a common thread but I thought I'd ask...
I've got a rust-free (hopefully) mk1 and how best to keep it that way? Clear out hood drain holes? Keep it in the garage? Under seal every fortnight??
Are there any bits to pay special attention to?
#2 Zed.
Zed.
  • 1570 posts
Posted 10 September 2020 - 07:28 PM
if the car lives in a garage, if it's dry then block the sill drains & fill the sills with waste engine oil (use the access holes under the door-sill covers to fill etc.)
leave a while to coat then drain...
then the sills / rear arches are flammable when the car needs welding :lol:
Bodger :ph34r:
#3 boosted
boosted
  • 1662 posts
Posted 10 September 2020 - 08:02 PM
Ive contemplated filling with a foam polyurethane....yet to do it!
#4 dadbif
dadbif
  • 745 posts
Posted 10 September 2020 - 09:42 PM
Moisture would not be able to drain away and become trapped between the steel and the foam 🙁
#5 Shadowraven
Shadowraven
  • 4479 posts
Posted 10 September 2020 - 09:45 PM
Yeh, seen a number of posts on FB with people finding this had been done on their cars and the rust had gotten really bad. Was also one hilarious one where someone had done it, the roof drains clogged, water couldnt drain out the sills, and the entire car became a swimming pool
#6 stashio
stashio
  • 12 posts
Posted 10 September 2020 - 10:16 PM
Ordinarily yes but that's where they missed the genius of Zed's oil/welding/flame/insurance combo :)
#7 Zed.
Zed.
  • 1570 posts
Posted 10 September 2020 - 11:01 PM
(takes a bow :whistle: )
:popcorn:
rust happens................
I weld therefore I know :lol:
Bodger :ph34r:
