Gearbox Filler Plug Stuck - Servicing - MX5Nutz Forum
11 replies to this topic
#1 Cliddoris
Cliddoris
  • 30 posts
Posted 31 August 2020 - 08:01 PM
Hey guys,
Was doing a full service of the car (94 mk1) so coolant flush, oil change for engine, gearbox, diff and a few other wee bits and pieces needing done.
Got round to the gearbox, as with a lot of things I do on the car, I spent 90% of my time fighting one thing, the gearbox filler plug.
The square 14mm plug, looking at it, it would seem someone has used thread locker in a past life and it is well in there.
I threw a load of penetrant on it then hit it with an adjustable locking wrench, putting everything I had I to it, ended up slipping off somewhat rounding, went back with a 14mm spanner and breaker bar, same issue.
Tried applying heat and no joy.
It's looking like this thing is due to stay in for the life of this box, any way I can fill the box up through the speedo cable hole or something?
Or if anyone has tips for these filler plus I'd be happy to hear, I have a spare 5 speed in my garage with twice the mileage as mine, filler plug came out no bother!
Cheers,
-EDIT-
Box is a 5 speed.
#2 Shadowraven
Shadowraven
  • 4467 posts
Posted 31 August 2020 - 09:50 PM
Sounds like it might be cross threaded. Nothing else I can really suggest apart from let it soak in penetrating fluid and apply more force.
#3 dadbif
dadbif
  • 741 posts
Posted 01 September 2020 - 07:02 AM
Have you got enough access to get a length of scaffold pole tube or similar on it to increase leverage?
#4 Rasc
Rasc
  • 2678 posts
Posted 01 September 2020 - 07:35 AM
Can you get your hands on an impact wrench? I find they are very useful, got myself a cheap electric one from Lidl’s a while back.
MK1 RS Ltd, Turbo, Tien Super Sport, Recaro's, BBS, 227 WHP
MK2 RS White, HKS turbo, Koni sports, Watanabe's
MK2 VS White, HKS turbo, Miester Rs, 949 ULs
#5 Ecosse
Ecosse
    Ecosse
  • 3858 posts
Posted 01 September 2020 - 08:45 AM
Thank God you've a spare box.
Age/miles is pretty irrelevant but I'm wondering?
It's not clear if you have actually drained the bothersome 'box?
As ever with these pesky things.....always ensure you can refill before draining.
Beware the imbecile you did not bargain for. Perhaps in a Zafira  at Tesco waiting to self combust.
#6 indykid
indykid
    Advanced Pedant
  • Moderators
  • 10049 posts
  • Gender:Not Telling
Posted 01 September 2020 - 12:17 PM
Heat will work, but you need to be getting the gearbox casing hot, not the plug, which takes a while. If you can still touch the box casing 4" away from the plug when you've done heating and it not feel notably warm, you probably haven't heated it enough.
A double square socket is a better bet than mole grips and being a tapered thread on the plug, it's certainly in liquid tight if not gas tight so penetrating fluid won't help. I've linked to a 9/16" socket, but check the size before you order anything.
#7 Zed.
Zed.
  • 1560 posts
Posted 01 September 2020 - 12:41 PM
+1 :thumb-up:
if its chewed then a 3' Stilsons are your friend :yes:
:whistle:
Bodger :ph34r:
#8 Cliddoris
Cliddoris
  • 30 posts
Posted 01 September 2020 - 07:01 PM
Thanks for all the replies guys!
I was sensible enough to not drain the gearbox before removing the filler and to be honest, I'd be putting off the gearbox oil change a few months as I had half a mind this would happen!
It's not completely rounded off yet, I've picked up a 14" pipe wrench, will get a long piece of scaffolding pipe to slip over it and borrow a friend's lift as I won't get much movement under jack stands and frankly, I don't fancy pulling that hard on it while I'm under jack stands.
The 9/16 double square socket would have been the ticket had I not already started to round it! I'll probably pick one of them up next time if I get this out.
But the plan is to go to town on this one at some point this week, if it comes out then this gearbox is due an oil change and shifter rebuild, failing that it will probably just be driven until it fails and replaced..... Hopefully the former.
I'll report back with either a sheered filler plug or a freshly serviced gearbox.
#9 Martin Y
Martin Y
  • 10336 posts
Posted 01 September 2020 - 08:02 PM
I do remember my first time removing that plug (and the diff plugs) I was getting nowhere until I borrowed the use of a lift.  With more room to work things that wouldn't budge suddenly did.  Only took moments to crack them loose and nip them up again before taking the car home to do the fluid changes.
Hope it works as well for you.
#10 Jim A
Jim A
  • 55 posts
Posted 01 September 2020 - 08:38 PM
In addition to through the fill hole, can refill your transmission through the speedometer sender hole or the driveshaft hole.
#11 Cliddoris
Cliddoris
  • 30 posts
Posted 01 September 2020 - 10:11 PM
This is good to know, I guess the risk is that you can over fill the box.
But I imagine a slightly over filled box of fresh fluid is better than a box that has an unknown age of oil in it.
#12 Martin Y
Martin Y
  • 10336 posts
Posted 02 September 2020 - 09:04 AM
If you use two 1 litre bottles, you won't overfill it.
