Spoilers From Non Mx5S - Exterior - MX5Nutz Forum
7 replies to this topic
#1 BEN99W
BEN99W
  • 336 posts
Posted 03 June 2020 - 01:33 PM
I fancy a small spoiler for my NB, but all the ducktail designs I see available run down to the bottom of the boot, covering the 3rd brake light and stretch a few inches forward too. I can see this gives a good surface area for bonding, but it seems overly substantial and I just dont like the look.
Currently lots of bmws such as the 2 and 3 series have a much neater lip spoiler which looks like it might fit an NB. I've also wondered if an old jag XType spoiler would fit. Theres also a small lip on the Toyota c-hr which might work.
Has anyone tried any alternative spoiler with success?
For fun I took the pop-up spoiler off my wife's mini Coupe and sat that on my boot. It looked like it could almost work but not quite and sorry no pic - the wife was about and I had to be quick!
Ben
#2 carl s
carl s
  • 1579 posts
Posted 03 June 2020 - 02:21 PM
I also wondered about this, I reckon the spoiler from the last generation Jaguar XK8 would fit
ex - mk3 2006 2.0 sport
ex - mk2 1999 1.8is JRSC
#3 BEN99W
BEN99W
  • 336 posts
Posted 03 June 2020 - 03:22 PM
The pre 06 xk8 looks like a good shout. The 06-on model has a 3rd brake light.
#4 carl s
carl s
  • 1579 posts
Posted 03 June 2020 - 05:46 PM
These people have two for sale:  https://www.ebay.co....YAAAOSwq1NeLWRb
#5 Shadowraven
Shadowraven
  • 4367 posts
Posted 07 June 2020 - 02:32 PM
I have a random one from ebay I think suits quiet well. Seen a few listed recently.
#6 dadbif
dadbif
  • 676 posts
Posted 07 June 2020 - 06:19 PM
Not for me, but they look nice.
#7 BEN99W
BEN99W
  • 336 posts
Posted 21 June 2020 - 12:16 PM
[quote name="Shadowraven" post="4524673" timestamp="1591540364"]I have a random one from ebay I think suits quiet well. Seen a few listed recently.
The car looks stunning Shadowraven, but the angle of the photo, combined with me trying to see it on my phone make it quite hard to determine the actual spoiler.
#8 Shadowraven
Shadowraven
  • 4367 posts
Posted 21 June 2020 - 09:33 PM
