Itb Build - Page 2 - Forced Induction & N/A Power Mods - MX5Nutz Forum - Page 2
Itb Build
27 replies to this topic
#21 Dickie
Dickie
  • 481 posts
Posted 22 August 2017 - 05:10 PM
Hi, Folks,
I have now grafted a Mk1 TPS onto the Danst set up which means when I do the manifold swap all the plugs stay the same, I just have to extend the wires to go to the back of the engine.
This set up will end up on a Mk2.5 block with Mk2 head with a 60 thou skim, gas flowed, de shrouded valves, piper 285 cams, supertech springs and caps, mazdaspeed SUB's, lighter flywheel, helix group N clutch with saab concentric slave cylinder conversion.
I need to sort out my ME221 to get the engine running properly before I swap to the ITB set up.
Cheers Dickie
#22 mbh69
mbh69
  • 956 posts
Posted 22 August 2017 - 06:44 PM
I'm going for a mk2.5 bottom end for mine but having it decked with forged rods and lighten and balance it all.
www.Fixascuff.co.uk
www.RicoRally.co.uk
97 Classic Red MK1 1.8 UKDM Fast Road/ Track Ms2 Megasquirt, Jenvey Itb, stage 2 cams & head, AEM Wideband, Adjustable Cam Pulleys, Aluminium Performance Radiator, Torsen 4.3 LSD, xpd Clutch, rpc Lightened Flywheel, 4-2-1 Manifold, Larini Exhaust, Meister R Coilovers, Axxis Pads, Braided Hoses, ATE Racing brake fluid, Jass Brake Stopper, Depowered steering rack, Track Alignment, Carbing Roll cage, Harness bar, GRP Seats, Harnesses
#23 Markcoopers
Markcoopers
  • 451 posts
Posted 22 August 2017 - 10:15 PM
my "heath Robinson" approach is less dramatic but hopefully as effective.
Set of old Mikuni PHH 40 carbs striped/sealed and converted to be as ITB's, Jenvey manifold, Mk2 fuel rail, custom mount stock 1.8 VTPS (so I can use a PnP ECU set up, Head has 42 thou skim, exintake cam mod, 3 angle seats.
My members ride mod sheet
Current project
http://www.mx5nutz.c...howtopic=197977
Original project
http://www.mx5nutz.c...howtopic=115781
#24 Dickie
Dickie
  • 481 posts
Posted 19 May 2020 - 06:34 PM
Hi Folks,
Its time for a refresh and update.
The car is finally all together and transported to the Rolling Road for a complete mapping session.
I had a call from the rolling road a couple of days later.
It was good news followed by bad !!
The good news was it was making 172 BHP after a bit of inlet cam swinging. :D :D :D
The bad news is that the rolling road locked down due to Covid the car has been away for two months now. :( :( :(
The better news is that they are going back to work on June 1st :)
They are expecting to find most of the cars with flat batteries when they go back into open up.
I have no more figures to share,
I should be better informed once the car is finished and MOT tested.
I am looking forward to seeing the power curve.
If it is still climbing at peak revs it will be worth building a forged block and upping the rev limit, and fitting big valves.
#25 robygodzilla
robygodzilla
  • 1167 posts
Posted 21 May 2020 - 04:25 PM
Excellent news, one of the reasons I got gsxr throttle bodies was because of your build.
#26 Dickie
Dickie
  • 481 posts
Posted 21 May 2020 - 05:44 PM
Hi Roby,
I got my GSXR ITB's From Dave Mac as he changed direction. ( Which is why I tagged onto the thread he started )
I have loosely based my engine on Quinns over in the USA.
My original plan was head work / cams with standard throttle body then as funds grew I was going to fit Jenveys.
I just went with what appeared in front of me that was affordable and fitted my vague plan.
This has always been an experimental build, with no timescale pressure,
I have a well equipped large playpen to indulge myself so storage is no problem.
I bought another Eunos Rs which I have used for the last six years as well as the car in my Avatar to play with.
I take part in Speed Hillclimbs in both the Eunos and the Austin 7 and look forward to trying out the new build Eunos on the hills later in the year if any events actually happen this year.
#27 Dickie
Dickie
  • 481 posts
Posted 28 May 2020 - 06:38 PM
Hi Folks,
I have been in touch with the Tuners, they have been back at work for a couple of days, my car is ready to come home :D
They have been unable to get it MOT tested for me so I will have to get the car home on a transporter then arrange for another garage to do the MOT test.
I will have to get a new cover note before I can take the car anywhere though.
Meanwhile I am making a pattern for  a custom airbox so I can reduce the intake noise and get some colder air to the intake.
#28 Dickie
Dickie
  • 481 posts
Posted 30 May 2020 - 07:30 PM
Hi Folks,
I now have a fresh cover note so I can collect the car from Engine Tuner Plymouth and drive it to a pre arranged MOT test legally even with no numberplates !
The mould for the ITB airbox has now been laminated , I will have to leave it overnight before I can take the mould off the pattern, then trim the mould and make a frame for it before I make the first airbox prototype.
