What Have You Done To Your Mx5 Today? - Page 603 - MX-5 / Roadster Forum - MX5Nutz Forum - Page 603
Mk1 Mk2 Mk3 Today
12051 replies to this topic
#12041 carl s
carl s
  • 1573 posts
Posted 11 May 2020 - 01:45 PM
That will have been eaten by the engine then! if it's only foam it's not going to have done any damage apart from letting unfiltered air into the engine.
ex - mk3 2006 2.0 sport
ex - mk2 1999 1.8is JRSC
#12042 BlueFive
BlueFive
  • 283 posts
Posted 11 May 2020 - 01:49 PM
Yes, that is only foam...and fortunately enough, I didn't run the car into too dusty places for the past 7months...
Sent from my Nokia 6.1 using Tapatalk
#12043 Zed.
Zed.
  • 1439 posts
Posted 11 May 2020 - 05:42 PM
subject of dust...
sandblasted a pair of front & rear top wishbones for my car, these are the lighter items from an early 5 and look to have suvived 30 years without  too much corrosion :)
lower wishbones are soaking in phosphoric acid solution for a few days before sandblast...
Bodger :ph34r:
#12044 Chris' UK Miata
Chris' UK Miata
    Miata GT25
  • 320 posts
Posted 14 May 2020 - 09:06 PM
Got a bit carried away with the power steering…
  • 1
Begi Miata GT25
Made in Japan - Raised in the USA - Grew up in the UK
8.5:1 84.5mm pistons/H-beam rods/ARP studs/ACL bearings
BP4W head, 2 & 3 angle valve seats, 264/264 cams/Double valve springs
Holset HE221w
ME221
Still broken
#12045 BlueFive
BlueFive
  • 283 posts
Posted 14 May 2020 - 10:22 PM
Actually this is a brilliant idea for oil cooler placement...!
#12046 Chris' UK Miata
Chris' UK Miata
    Miata GT25
  • 320 posts
Posted 14 May 2020 - 10:49 PM
Thanks Blue! The engine oil cooler is in the bumper on the offside with a cowling that I have fab'd up. Will run a hose from the nostril on the bumper cover and one I've vented the top of the wing, the hot air should find its way :)
Begi Miata GT25
Holset HE221w
ME221
Still broken
#12047 Chris' UK Miata
Chris' UK Miata
    Miata GT25
  • 320 posts
Posted 26 May 2020 - 05:10 PM
Installed my coolant re-root… Turns out an air-conditioning compressor bolt is the perfect length for the deep side of the Kia thermostat housing...
Begi Miata GT25
Holset HE221w
ME221
Still broken
#12048 Shadgrind
Shadgrind
    Torque Setting - Up to shear & back a flap😄
  • 1053 posts
Posted 31 May 2020 - 09:08 PM
Decided against getting alcantara dash after seeing the price £££
So re-covered my own.
  • 1
My fourth MX - 5, after two NB's and an NC, now got a 184BHP ND!
#12049 Jabx123
Jabx123
  • 39 posts
Posted 05 June 2020 - 12:22 PM
The nc is going due to the bosses ( wife ) failing back spent yesterday removing the double din stereo, the mx5 parts wind deflector and the smarttop device and the retrimed steering wheel it took nearly as long to take it out as it did to put it all in
#12050 Zed.
Zed.
  • 1439 posts
Posted 29 June 2020 - 09:43 PM
Bodger :ph34r:
#12051 1outof5
1outof5
  • 200 posts
Posted 30 June 2020 - 05:57 AM
Are those alloy or steel?
#12052 Zed.
Zed.
  • 1439 posts
Posted 30 June 2020 - 09:39 AM
cast alloy centres welded to spun alloy rims (I believe, definately something along those lines :yes: )
will know better when I've got them & given them a gentle sandblast
Bodger :ph34r:
Also tagged with one or more of these keywords: Mk1, Mk2, Mk3, Today
