Severe Vibrations From 120Kmph (70Mph) And Up - Wheels, Tyres, Suspension & handling/etc - MX5Nutz Forum
30 replies to this topic
#1 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 01:08 PM
Dear all,
Also had some help on facebook from some Nutzerz but the post seems to die quickly there.
I've been chasing a severe vibration in my car that has been occurring at 120kmph and gets very uncomfortable at 140 and starts to be terrifying at 160kmph and i dont dare to go any further to see if it disappears. (I expect it won't)
At first i thought it was the known shimmy of course and had my wheels balanced multiple times at multiple garages. Eventually i bought new wheels and transferred over my tires. Issue didn't disappear so I had the wheels balanced once more.
There is no change noticeable in any of these attempts to get the wheels balanced. Because I also suspected the tires i swapped around wheels front to back in combination with 2 other wheels and tires i have laying around for drifting.
When all this playing around with wheels and tires didnt fix anything i started looking into other things, up till now I did the following:
++ Aligned PPF (about 5 times all at different heights, varying from completely sagged down till 72mm between the straight edge and the PPF (Mx5 handbook spec)).
++ Rotated prop shaft 180deg
++ Swapped prop shaft for another one
++ Swapped gearbox
++ Swapped wheel axels
++ Swapped wheel bearings (all 4)
++ Retorqued engine mounts
++ Retorqued Diff mounts
Several other facts:
++ When i'm doing 140 on the highway and i press the clutch and pull the shifter out of gear and let the engine drop to idle the vibration persists
++ Shifter is shaking violently around 140
As a diagnostic step I had the car in the air and did 140 in the garage, there was vibration but it seemed different. Only odd thing was that my tyre seems out of balance a bit but not sure how representative something like that is when theres no pressure of the road on the tyre. Also the fact that i used multiple different tires didnt make me think to much of this.
Garage vid 1
Garage vid 2
https://youtu.be/iK1GIKeeGRk
Garage vid 3
https://youtu.be/CLPL4LNNwVE
Only things i havent swapped that I can still think of are Diff mounts and the Diff itself.
Any help is appreciated.
Kr
Jarno
#2 Shadowraven
Shadowraven
  • 4358 posts
Posted 10 May 2020 - 01:17 PM
Are your engine mounts ok, they are often shagged and it's hard to tell without removing them.
Other suggestions-
 clutch or flywheel out of balance (if these have been done recently)
 suspension bushes shot
 as you said diff mounts might be shot, or any mounts affecting the rotating assembly
 are all wheels the correct centre bore (be it with spigot rings or just as they are)?
 all suspension bolts done up correctly?
 quality brake rotors (if these have been changed recently) as some cheap ebay ones can be unbalanced
#3 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 01:30 PM
Other suggestions-
Hi Shadowraven, Thanks very  much for taking the time to answer me :)
Diff mounts are strongflex PU about 2 years old,
The engine mounts are re-torqued recently and are the Fab9 PU ones (softest version).
Rear rotors are original from factory still, they are straight. (car only did 50k miles since 1992)
Suspension bushes seem OK.
Flywheel and clutch are FM happy meal kit. They are swapped in about 5 years ago.
Would you expect the flywheel/clutch assembly to still be able to cause this even if vibration persists @ 140kmph with the clutch pressed in and shifter pulled out of gear?
Because of this ive been focussing on any thing that is affected by road speed rather than engine speed. (Gearbox and back + front wheels/bearings)
Wheels are brand new with correct spigot rings as well indeed.
#4 Quinvy
Quinvy
    Phil.
  • 1782 posts
Posted 10 May 2020 - 01:59 PM
When did this problem start? Was the car perfect before? Had you done anything to the car just prior to getting the vibration?
#5 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 02:10 PM
Hi Quinvy, thanks for your input.
Car was straight as an arrow 2 years ago. I did couple sessions on Zandvoort track doing 200kph on the straight. I had different Tires and maybe stock diff mounts still.
To me seems to have gotten worse gradually over past months, car was ok at the end of last summer. I had these tires and diff mounts already then for sure. So i know for sure the car has been OK with these tires and diff mounts before. Thas also what makes it very hard to track for me. Its not like i changed 1 thing and the car started to vibrate suddenly. Even though it might have been the hardtop tention but took that off yesterday to test aswell.... no change.
Furthermore i didn't change anything drivetrain related.
Kr
Jarno
#6 Shadowraven
Shadowraven
  • 4358 posts
Posted 10 May 2020 - 02:41 PM
Other suggestions-
It's unlikely to be the clutch/flywheel after so long then. But yes in neutral the flywheel is still spinning.
I have no idea what it could be, that it's started when you havent changed anything and is gradually getting worse does suggest a wearing item to me though.
#7 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 04:44 PM
Yes i agree. Only thing left to swap in my kind is the differential. Though me personaly cant immagine a diff wear in this way. Most of the times diffs that break dont break from wear, more like pieces breaking off and granading them selves as a result. Only thing would be the bearings in the diff...
#8 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 04:45 PM
I will call my local shop again tomorrow to align the tires and wheels once more. They got a new balancing mavhine recently
#9 Quinvy
Quinvy
    Phil.
  • 1782 posts
Posted 10 May 2020 - 06:53 PM
This is a very baffling problem indeed. I don't know what to suggest. It must be driving you insane.
Good luck with solving the problem, please keep us informed how you get on.
#10 dadbif
dadbif
  • 674 posts
Posted 10 May 2020 - 07:26 PM
Driveshaft joint, many years ago I had a similar problem on a Mondeo.
#11 Zed.
Zed.
  • 1438 posts
Posted 10 May 2020 - 07:41 PM
Driveshaft joint,
+1 :yes:
or propshaft :whistle:
OR...
loose propshaft bolts
(hopefully not loose wheelnuts :doh: )
Bodger :ph34r:
#12 Jim A
Jim A
  • 46 posts
Posted 10 May 2020 - 07:45 PM
Differential pinion bearing.  Jack up and jack stand the rear end so it’s safe and secure.  Grab the rear of the driveshaft just ahead of the differential.  Give it a mighty shake!  Any movement, and there’s your problem.
It could also be a driveshaft joint, but you’ve already swapped driveshafts, and so that would mean that both shafts would have had a bad joint(s).
You could repeat your experiment of spinning the drive train with the back of the car off of the ground, and with the wheels removed (replace the lug nuts to secure the brake disks).  That will eliminate wheels and tires from the equation.
#13 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 07:57 PM
Regarding the diff pinion, i did exactly that, theres no play what so ever. Theres even more play on the gearbox side on either gearboxes.
Regarding the garage testing with the wheels off, thats a good idea havent tried that yet. A mate of mine offered to swap his wheels on my car to be absolutely sure i have properly balanced wheels on my car. Will try that tomorrow.
#14 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 07:59 PM
Driveshaft joint,
+1 :yes:
OR...
Tried 2 driveshafts, had my driveshafts and wheels of about 10 times in 3 weeks diagnosing this issue. Its no loose bolts i cab tell you that haha 😝
#15 carl s
carl s
  • 1573 posts
Posted 10 May 2020 - 09:27 PM
I would agree that it doesn't seem to be likely it's engine or clutch related.  However it could be the propshaft that has thrown a weight? or maybe one of the propshaft nuts/bolts has come lose as Zed said but as you mentioned that you have swapped this it can't be..  If it was within the differential it's hard to tell but I would put my money on it being that, the reason why is because the guy who runs carpassionchannel on Youtube had a very similar issue when he swapped gearboxes turbos, wheels and just about everything else.  The vibrations all went away when he swapped out his diff, you can see the final episode here (yes i know he swapped to a Cadalac Diff) but he swapped from a MX5 diff which was causing the issue: https://www.youtube....Fcszqjso&t=491s
There's about five previous videos where he details all the things he tries to get rid of the vibrations but this one shows the problem the best: https://www.youtube....1sEIe-2s&t=544s
Good luck but my money is on the diff  :thumb-up:
ex - mk3 2006 2.0 sport
ex - mk2 1999 1.8is JRSC
#16 jarno
jarno
  • 450 posts
Posted 10 May 2020 - 09:39 PM
Hi Carl, thanks alot for uour input. Ive seen his vids, but didnt he say he swapped out his diff for another mx5 diff aswell before to diagnose the vibrations? I might be mistaken. If the vibrations are still there tomorrow after swapping over the wheels from my mate the diff will be next indeed.
#17 carl s
carl s
  • 1573 posts
Posted 10 May 2020 - 09:47 PM
That might be true it's been a while since I watched all the videos, he changed the diff, propshaft, mounts & driveshafts so it has to have been one of those. You have already changed the propshaft and checked the mounts, In your list you mention you changed the wheel axles do you mean the driveshafts that go between the diff & hubs?
#18 jarno
jarno
  • 450 posts
Posted 11 May 2020 - 06:53 AM
Yes i swapped all 3 axels so to say. 2 axels from diff to hubs and the prop shaft between transmission and diff.
#19 dadbif
dadbif
  • 674 posts
Posted 11 May 2020 - 07:54 AM
I know you’ve changed just about everything, but could your PPF be loose? But then that would rattle all the time not get worse as revs increase.
Logic says it is something rotating that is out of balance,
If it’s not an external joint then it could be the diff, can you freel any play on the inner driveshaft joints/diff bearing?
#20 jarno
jarno
  • 450 posts
Posted 11 May 2020 - 08:02 AM
Thnx for your reply dadbif. Ye ive inspected the PPF for cracks even haha. Theres no play on any of the rotating shafts joints. Only the slip joint between the gearbox and driveshaft has very minor play but thats on both gearboxes and both driveshafts😁. But looking at the fact that this joint has an oil bearing surface and no ballbearing i would expect a very very minor play as the oil wouldnt be able to do its job without. All ppf bolts have been loose at the gearbox swap and torqued after.
