1.8 Na M62 Supercharger Build - Page 8 - Forced Induction & N/A Power Mods - MX5Nutz Forum - Page 8
141 replies to this topic
#141 Shadowraven
Shadowraven
  • 4817 posts
Posted Today, 02:39 PM
Interesting. My bracket fouled on that bolt so I needed to remove it.
I've a solution for my IC routing now. Actually super easy, works with large rad, AC, stock fans and AC fan. Had some pipes arrive today so can mock up as soon as figure out how to mount the IC properly.
#142 Hexxeh
Hexxeh
  • 58 posts
Posted Today, 02:41 PM
Be interested to see that!
The clip attached to the front of the bolt did foul, but it was fairly flexible so I just bent it slightly out the way...
