Nb Wiring- Unknown Plug - Mechanical & Electrical - MX5Nutz Forum
Wiring Starter connector
13 replies to this topic
#1 MX5Spitfire
MX5Spitfire
    One post wonder
  • 7 posts
Posted 13 May 2020 - 12:30 PM
Hi all,
I am putting an UK NB engine into a Triumph Spitfire (it seemed a good idea at the start..)
I have a standard ECU, main wiring loom, engine wiring loom and charging loom. (ECU has matching ignition barrel, key and immobiliser)
Starter gets the main power feed but not the signal feed on turn of the key (and it can be turned and engaged by wiring direct to the ignition feed)
I traced this connector- link below (close to the immobiliser unit, 2 white 2 white/ black wires going into it) which has gets power on turning to start.
Does anyone have any idea what this should be connected to? (or if its a red herring!) I've  Haynes manual on the way as the only wiring diagrams I could find were US spec.
Any thoughts appreciated!
Cheers,
David
https://photos.app.g...s2VoHsvhr3q9uJ8
#2 boosted
boosted
  • 1457 posts
Posted 14 May 2020 - 05:57 AM
Have you tried mellens.net for wiring diagrams?
#3 MX5Spitfire
MX5Spitfire
    One post wonder
  • 7 posts
Posted 15 May 2020 - 09:12 AM
Not yet but I will today! Thanks Boosted.
#4 boosted
boosted
  • 1457 posts
Posted 15 May 2020 - 09:22 AM
Excellent resource for mazda wiring...ive seen that 4 pin plug on a mk2.5 but my memory fails me.
#5 Zed.
Zed.
  • 1443 posts
Posted 15 May 2020 - 09:54 AM
do they have a clutch-pedal interlock system (pedal needs to be pressed to engage the startermotor) :confused:
Bodger :ph34r:
#6 boosted
boosted
  • 1457 posts
Posted 15 May 2020 - 10:52 AM
Never come across any mazda apart from the Wifes rx8 R3 2010 that had that feature..dont think on any 5 though.
#7 Chris' UK Miata
Chris' UK Miata
    Miata GT25
  • 320 posts
Posted 17 May 2020 - 12:25 AM
That’s what the wiper motor plug looks like on my lefty
Begi Miata GT25
Made in Japan - Raised in the USA - Grew up in the UK
8.5:1 84.5mm pistons/H-beam rods/ARP studs/ACL bearings
BP4W head, 2 & 3 angle valve seats, 264/264 cams/Double valve springs
Holset HE221w
ME221
Still broken
#8 MX5Spitfire
MX5Spitfire
    One post wonder
  • 7 posts
Posted 17 May 2020 - 10:11 AM
Cheers all- that link is great and I got my Haynes manual through as well!
Haynes suggests that the wires go to a relay, but I have never seen a relay with that pattern! (I need this lockdown over so my mechanic mate can come help me with this :-) )
#9 MX5Spitfire
MX5Spitfire
    One post wonder
  • 7 posts
Posted 17 May 2020 - 10:12 AM
I kept reading about this as well, though it looks like UK spec didnt!
#10 Zed.
Zed.
  • 1443 posts
Posted 17 May 2020 - 10:19 AM
trace the wires, if one pair are an interruption of the startermotor activator then thats your answer :yes:
^^ related...
if thats the case, the other pair would feed to the ecu (cutting power while clutch depressed - a safety feature.............) or cruise module (if fitted OR if an option?? :confused: )
Bodger :ph34r:
#11 Chris' UK Miata
Chris' UK Miata
    Miata GT25
  • 320 posts
Posted 17 May 2020 - 10:25 PM
^^ related...
Cruise is a good shout. A quick search threw this up (I could have just checked my car but I tucked all the wiring away )
Begi Miata GT25
Holset HE221w
ME221
Still broken
#12 MX5Spitfire
MX5Spitfire
    One post wonder
  • 7 posts
Posted 18 May 2020 - 10:19 AM
Thanks all for the responses, most helpful.
I think there is a relay that is missing (and i have found a relay that will fit the unusual relay pattern! I have ordered the 2 different relays with that pattern to give them a go!
Will update when they come it. wiring from here goes to the immobiliser and starter so i am hopefully on the right track!
#13 MX5Spitfire
MX5Spitfire
    One post wonder
  • 7 posts
Posted 21 May 2020 - 10:20 AM
So it was a missing relay! Got one through today and it now turns over on the key. Not yet running but certainly a step closer! Thanks again all.
#14 Chris' UK Miata
Chris' UK Miata
    Miata GT25
  • 320 posts
Posted 22 May 2020 - 04:32 PM
That’s brilliant!
Begi Miata GT25
Holset HE221w
ME221
Still broken
