Momentary Cut Out - Forced Induction & N/A Power Mods - MX5Nutz Forum
Momentary Cut Out
2 replies to this topic
#1 silverfox 1
silverfox 1
  • 43 posts
Posted 14 October 2020 - 05:11 PM
Hi I have a 2005 1.6 It has an Eaton m45 supercharger with a 64mm 2nd throttle body going thru an intercooler and exit thru a ss exhaust with fast cat , there is a blow off valve connected back in to the air intake after the Maf  and track dog ignition and fuel cards
The problem I  have is  that if I'm under boost and ease back it is as if there is a momentary cut out, strangely this does not happen if I come off the gas quickly. I have synchronized both throttle bodies so that they open together, the 64mm opening  both slightly before and after the engine throttle body but nothing seems to make much difference.
It drives me mad any advice would be appreciated
#2 Benmm
Benmm
    One post wonder
  • 7 posts
Posted 15 October 2020 - 10:07 AM
Have you confirmed the BOV isn’t opening? If you don’t lift enough to open the SC bypass valve (assuming you have one fitted) then you might be building up enough pressure drop across the throttle to activate the BOV.
#3 silverfox 1
silverfox 1
  • 43 posts
Posted 16 October 2020 - 11:38 AM
Hi   thanks I will try that,  to be honest I have suspected problems with the BOV as i am only getting 3.5psi boost and if you do the maths it should be 8 plus
cheers
