Hawk's Mk1 Supercharge Project - Page 20 - Members Rides - MX5Nutz Forum - Page 20
434 replies to this topic
#381 B_hawk111
B_hawk111
  • 600 posts
Posted 02 June 2020 - 07:32 AM
Nice work as always.
Why did you remove the ABS?
Main reason is it really limits the space for the supercharger inlet!
Bit it's also heavy, a bit useless, and in 5 years its only helped me twice, both times in winter, both tines in the rain.
Both of which I don't do any more 😉
  • 1
#382 B_hawk111
B_hawk111
  • 600 posts
Posted 02 June 2020 - 09:13 PM
A bit more done today!
My coil pack wiring loom has been a bit dodgy for a while. Both clips have snapped off, and I had to repair a wire last winter!
So I have replaced the coil connectors with ones from a spare loom, and then tidied up the rest of it!
49964132738_2ede78f966_c.jpg20200602_132913 by ben hawkes, on Flickr
And then came up with what I thought was a clever idea to fill the gearbox oil
49964132578_7e8f719fd7_c.jpg20200602_154502 by ben hawkes, on Flickr
49964636061_2e1ca5f96c_c.jpg20200602_154524 by ben hawkes, on Flickr
Hard pipe makes it easier to position the pipe and the bottle just glugged away into the pipe!
Also got the Mk2 throttle body cleaned up, bolted and connected up, then fitted up the rest of the coolant pipes, wiring and vac pipes!
49964132288_88c0548542_c.jpg20200602_160319 by ben hawkes, on Flickr
Should be ready to refill the coolant tomorrow, give the brakes and clutch a final bleed and get the manifold in the spray booth for ceramic coating!
I gave the exhaust tip a quick clean up and fitted back on,
49964132428_69d853dfc4_c.jpg20200602_173713 by ben hawkes, on Flickr
I'm also attempting to get the VSS working on the me221, I think I've worked it all out, just need to try and work out which input on the ecu to use!
Also turns out a dewalt drill will run the speedo at 80mph 😂
#383 B_hawk111
B_hawk111
  • 600 posts
Posted 03 June 2020 - 01:36 PM
Popped into work and got the manifold in the spray booth!
49966429528_5dfcb7474d_c.jpg20200603_113510 by ben hawkes, on Flickr
I was hoping to give this to a friend to ceramic coat, but due to covid he lost his job which is terrible for him!
He was kind enough to put me onto the ceramic paint they used at his firm, and it turns out it comes in all sorts of colours!!
49967210397_9602499f50_c.jpg20200603_113706 by ben hawkes, on Flickr
Isn't cheap stuff, but it only takes one coat, so the exhaust is done, and I've still got over half the tub left! So once I've modified the intercooler pipes, they are getting the same treatment!
49966429483_7480b23be8_c.jpg20200603_115508 by ben hawkes, on Flickr
Should help keep the engine bay temps down! And I really hate exhaust wrap so solves that problem too! Still going to run the TDR manifold blanket as before, although that is not looking too good!
#384 carl s
carl s
  • 1579 posts
Posted 03 June 2020 - 07:54 PM
love it!
ex - mk3 2006 2.0 sport
ex - mk2 1999 1.8is JRSC
#385 B_hawk111
B_hawk111
  • 600 posts
Posted 03 June 2020 - 08:55 PM
love it!
Simple eh!! Worked great!
#386 B_hawk111
B_hawk111
  • 600 posts
Posted 03 June 2020 - 09:25 PM
So more new stuff arrived today!
Well I say new! Very dirty and well used! But super cheap!
49968185746_40313847e8_c.jpg20200603_193534 by ben hawkes, on Flickr
Gave it a good clean up and then stripped it apart to check the spring!
49967673168_49742a4f48_c.jpg20200603_194947 by ben hawkes, on Flickr
Must have been running some big boost, had a blue spring in which is rated for 23-30psi apparently!
I've ordered the green spring which is good for 6-15!
Just need the pipe to turn up so I can get it welded on!
Oh and after a bad start with a dodgy paint gun, I've borrowed the decent gun from my work and got the hardtop in epoxy!
49967673153_e403273b3f_c.jpg20200603_204232 by ben hawkes, on Flickr
Will need some serious sanding tomorrow to get the first guns attempts at ruining it off, but should be in filler primer before tomorrow evening! And hopefully the car will be back up and running too!
#387 Shadowraven
Shadowraven
  • 4370 posts
Posted 04 June 2020 - 11:07 AM
Bit more done today!
Old clutch out!
49953438161_ae23aacd97_c.jpg20200530_114328 by ben hawkes, on Flickr
So what I'm hearing is you are well practiced, want to help me do mine on the track car? it's a 50k mile super clean car lol
#388 B_hawk111
B_hawk111
  • 600 posts
Posted 04 June 2020 - 11:30 AM
Old clutch out!
Mate, it is my most hated job 😂
My only advice is to just remove everything! The more shit you unbolt the easier it is to get the gearbox off and on!
#389 Shadowraven
Shadowraven
  • 4370 posts
Posted 04 June 2020 - 03:13 PM
Lol. Yeh, I've all the SVT bracing as well, fun times.
#390 B_hawk111
B_hawk111
  • 600 posts
Posted 04 June 2020 - 09:36 PM
Manifold is back on!
49971514661_2a22d32983_c.jpg20200604_105053 by ben hawkes, on Flickr
49971777162_cacf9b90a0_c.jpg20200604_164627 by ben hawkes, on Flickr
Looks really cool, but as long as it functions and keeps the temps down that's all that really matters!
I also finished ripping out the abs! Ran a new alarm wire into the boot, seemed pointless having the bonnet alarmed and the boot not, especially as you could just open the boot and unplug the battery!!
And lastly I spent a few hours trying to work out how to get the vehicle speed sensor working through the me221.
Main reason is to disable launch control when moving, so it removes the need to have clutch switches and stuff!
After a lot of reading, I finally worked out how to wire it all in and get it working using the Reed switch on the clocks that was used for cruise control.
First weird thing I found was that I already had the wire on the clocks loom!
Multi metered that and it was connected down to the ecu!
But more multi metering showed it all worked as expected, but my research said I needed to feed a 5v pull up into that wire otherwise it won't work.
I then decided to plug the ecu into the laptop and see if it reads anything.
Turns out after all that and 3 years of having the ecu fitted to my car, the VSS works perfectly already!
Guess that's what I get for having this odd crossover year car and not actually checking!
Ah well, interior can go back together tomorrow, then run the car up and check the new throttle body, cabling I've changed, and bleed the coolant! Then onto some fun bits!
#391 B_hawk111
B_hawk111
  • 600 posts
Posted 05 June 2020 - 09:12 PM
Good amount more done today!
Bled the coolant, it ran up to temp nicely, one small leak from a badly seated pipe so sorted that and away it went!
Let it run up till the primary fan kicked in and it dis its job nicely pulling the temps back down.
Then as a test I unplugged the primary and once it got a few degrees hotter the secondsry fan kicked in and again pulled the temps right down.
Then rewired my launch control switch, put the interior back together, bled the clutch and re bled and checked the brakes, one small leak again, fixed by just tweaking the fitting a bit tighter!
And finally fitted a new wideband sensor and put the TDR manifold blanket back on!
Oh and sprayed the hardtop with filler primer!
Tomorrow is going to be colour and clear on the inside, then hopefully early next week colour and clear on the outside!
49975130112_ea05d5864a_c.jpg20200605_185919 by ben hawkes, on Flickr
49974347128_f9a12beb1c_c.jpg20200605_185922 by ben hawkes, on Flickr
49975129852_64b2928516_c.jpg20200605_190416 by ben hawkes, on Flickr
49974347038_7c4f56a40a_c.jpg20200605_190426 by ben hawkes, on Flickr
#392 carl s
carl s
  • 1579 posts
Posted 05 June 2020 - 09:40 PM
Interesting that you have two fans, I have my a/c fan still fitted (despite the a/c not being there any more) I was wondering if it was worth wiring it in and what to use to trigger it.  I do have an ME221 fitted...
#393 B_hawk111
B_hawk111
  • 600 posts
Posted 05 June 2020 - 09:48 PM
I had problems with my fan last year and it lead to the car overheating a couple of times!
I replaced the main fan and just thought I might aswell just mount up the old one as a backup!
If your old fan is still wired in, you should be able to trigger it from the me221!
If not its quite easy to wire up.
The me221 switches ground, so just use it to run a relay to power the fan.
#394 B_hawk111
B_hawk111
  • 600 posts
Posted 06 June 2020 - 09:47 PM
Today I was going to spray colour and clear on the inside of the hardtop!
I changed my mind though, and decided to spray the inside with filler primer first too! Hopefully it will get a good finish all over then!
49977852878_9434759412_c.jpg20200606_125145 by ben hawkes, on Flickr
My new spring turned up from forge too so I got the dump valve rebuilt and ready to go!
49978633067_bb42463de9_c.jpg20200606_133213 by ben hawkes, on Flickr
49978372161_a764635196_c.jpg20200606_133530 by ben hawkes, on Flickr
I also started to prepare the intercooler pipes for modifying and paint!
The dei gold heat reflective tape is a real pain to get off! It's taken a lot of effort to get the glue off! But it's almost there! Just news my 25mm pipe to arrive to weld on!
49977852628_8c2e33e4cc_c.jpg20200606_133702 by ben hawkes, on Flickr
#395 B_hawk111
B_hawk111
  • 600 posts
Posted 07 June 2020 - 09:54 PM
Took a dry 20 minutes to start sorting the charger out, removed all the complicated pipework which was once needed to avoid the abs system!
Before!
49982426847_223252cf83_c.jpg20200607_121021 by ben hawkes, on Flickr
49982170571_90125fe45a_c.jpg20200607_121025 by ben hawkes, on Flickr
After!
49981646813_14d1e46ec4_c.jpg20200607_123040 by ben hawkes, on Flickr
49982426502_0427291e12_c.jpg20200607_123043 by ben hawkes, on Flickr
So much neater and cleaner! I've ordered the new couplers for the bypass valve and for the dump valve! Still just need to weld on the outlet for the dump valve but the pipes stuck with snail mail!
Then while it rained today I got the inside of the hardtop painted!
I mixed some of the black I plan to use for the outside with some purple I had from a bike frame! Made a really cool almost red tinged black!
49982426167_0f7979fb2b_c.jpg20200607_180141 by ben hawkes, on Flickr
49982169796_4e9c7b40a9_c.jpg20200607_180154 by ben hawkes, on Flickr
49981646293_8d1e53a035_c.jpg20200607_191810 by ben hawkes, on Flickr
Need to leave that a few days now to harden before I flip it over and paint the outside! Quite pleased with the finish though! Much better then scuffed and chipped satin black!
#396 B_hawk111
B_hawk111
  • 600 posts
Posted 08 June 2020 - 09:56 PM
Got the car back in its wheels today finally! And started working on intercooler pipework and re fitting the supercharger!
The hot side intercooler pipe was always a bit of a pain as the silicone 45° bend was too small for the intercooler pipe, but also rubbed on the power steering pump!
So I decided to weld in a hard 45° bend and just use a straight reducer to fit it!
49985339598_d182c7f520_c.jpg20200608_153434 by ben hawkes, on Flickr
49985339463_aa16138d0a_c.jpg20200608_153647 by ben hawkes, on Flickr
49985339543_6fa5a050c3_c.jpg20200608_154520 by ben hawkes, on Flickr
Works loads better, so that was welded up and ground flat, very happy with it!
49985856391_f450e2ef7b_c.jpg20200608_183404 by ben hawkes, on Flickr
Then after waiting all day for it to arrive, I finally could weld in the outlet for the dump valve!
49985856146_43d3bea8b3_c.jpg20200608_201917 by ben hawkes, on Flickr
49985856086_ba8fa0cbab_c.jpg20200608_202459 by ben hawkes, on Flickr
So just waiting on a few bits of silicone to join the bypass up, and for the dump valve and it should be good for a test drive!
Also today I shortened the theottle cable, and ran the vaccume hose for the bypass valve. And also ran the pipe back in for the breather.
Almost ready to take off for mapping again!
#397 B_hawk111
B_hawk111
  • 600 posts
Posted 09 June 2020 - 08:31 PM
Decided I couldn't wait for the proper pipes to arrive, so bodged some bits together and gave it all a go!
Pipes and dump valve look good!
Theottle is nice and light still which is good!
Dump valve seems to opperate properly!
Big piston opens at idle but the little one stays shut to keep it all sealed, then as boost builds big piston shuts.
I tried to rev it up enough to build enough boost to try and make it vent properly but it blew my makeshift pipe off 😂
Shall have to wait for proper pipes before I can give it the proper sound test
49989196131_e4b35c6d19_c.jpg20200609_161326 by ben hawkes, on Flickr
Oh and this is the box of stuff that has so far been removed from my car in place of the new simple non abs system! And this doesn't include the actual abs components!!
49988677468_f411f00ac8_c.jpg20200609_163444 by ben hawkes, on Flickr
#398 B_hawk111
B_hawk111
  • 600 posts
Posted 10 June 2020 - 08:19 AM
Short video on my Instagram before the pipe blew off 😂
https://www.instagra...d=17r8h3x2nq6ek
#399 B_hawk111
B_hawk111
  • 600 posts
Posted 10 June 2020 - 09:38 PM
Gave the car a well deserved and much needed clean this morning!
49992939931_b7646693b5_c.jpg20200610_121951 by Ben Hawkes, on Flickr
And then I had an unexpectedly early delivery of all the silicone hoses and joiners I needed from ASH!
So that all went in and together!
49992418243_8035218978_c.jpg20200610_152340 by Ben Hawkes, on Flickr
49992939711_776116175d_c.jpg20200610_152352 by Ben Hawkes, on Flickr
I've changed the coolant overflow line now so it turns 90° and runs around behind the radiator instead of directly under the intercooler pipe!
Works much better but I had to cut down the outlet on the radiator as it was still too long, and in doing so I think I unscrewed it ever so slightly so it started leaking.
Then it started raining so I only got a quick run up and down the road to check things are working, which they are!
The new bofi clutch feels great, literally no different in terms of bite or feel to the exceedy one, but can apparently hold 400bhp!
And then more unexpected delivery's arrived!
49993187612_1f6471c1ac_c.jpg20200610_201208 by Ben Hawkes, on Flickr
Finally managed to find where to buy jetex racing air filters! So got myself an identical (but much newer and less squashed) air filter!
49992417778_08dab1635b_c.jpg20200610_201237 by Ben Hawkes, on Flickr
And some Fresh plugs!
49993187532_d7a27b222c_c.jpg20200610_201249 by Ben Hawkes, on Flickr
And some fresh rubbers for the hardtop!
Speaking of which!
49993188012_e1d651b246_c.jpg20200610_185735 by Ben Hawkes, on Flickr
49993187912_e1d9aa1055_c.jpg20200610_185740 by Ben Hawkes, on Flickr
That is the outside all flat back and ready for some colour and clear!
Sanding makes such a mess and I hate it, but hopefully I've done a good enough job to get a decent finish on it!
Shall find out tomorrow!
#400 carl s
carl s
  • 1579 posts
Posted 10 June 2020 - 10:38 PM
Great progress, I crawled around in the rain under my car today, nothing as successful as you! with that intake have you ever considered taking the air from the windscreen bulkhead? just a quick 90 degree bend and you've got a cold air randell-style intake to the supercharger.
