Electric Aerial Upgrade - I.C.E - MX5Nutz Forum
6 replies to this topic
#1 SootySport
SootySport
    One post wonder
  • 9 posts
Posted 23 September 2020 - 07:50 PM
I have a 2001 car with radio/cd, 2192 label on the front panel. The original aerial is fixed non telescopic and I reckon it’s going to be vandalised within a few days. Does this HU have a connection for operating an electric aerial? so I can upgrade.
#2 Shadowraven
Shadowraven
  • 4508 posts
Posted 23 September 2020 - 10:52 PM
I'm pretty sure the power connection for an electric aerial is part of the chassis harness, and they all have it. I upgraded my 2001 with no issues, literally plug and play. Mine was the most poverty spec base model, standard mirrors, fixed aerial, 14" alloys, open diff, etc, swapping everything to electric was super easy as all the harness connections were there.
#3 SootySport
SootySport
    One post wonder
  • 9 posts
Posted 23 September 2020 - 11:24 PM
Yes I read that in another thread but does the HU raise the aerial when it's switched on?
#4 Shadowraven
Shadowraven
  • 4508 posts
Posted 24 September 2020 - 08:48 AM
Yes as far as I know they all do.
#5 SootySport
SootySport
    One post wonder
  • 9 posts
Posted 24 September 2020 - 01:05 PM
Thanks, I’ll find an aerial and root around the boot for the harness.
#6 colin565
colin565
  • 360 posts
Posted 28 September 2020 - 10:02 PM
If you cannot get the head unit to power the aerial up and down , then just fit an up/down switch at the dash, suitably fused.
A lot of aftermarket electrical aerials come with the up/down switch as a kit, may be worth getting that.
Have a look at Ebay.
#7 SootySport
SootySport
    One post wonder
  • 9 posts
Posted 10 October 2020 - 03:02 PM
Found a Mazda electric aerial and fitted that but the radio has died now. Also bought the Haynes manual so the wiring diagram will help.
