Steering Wheel Puller For My 2007? - Interior - MX5Nutz Forum
20 replies to this topic
#1 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 30 January 2021 - 10:04 AM
I've placed an order with Royal Steering Wheels (exciting stuff!) and once it arrives, I have 2 weeks to return my original and get my £100 deposit back.
I'm feeble  :D  and think I will need a puller to get the steering wheel off, but I don't want to spend £30 to use it once. Can't find a hire place around the Northwich area. Halfords and Screwfix don't have them on their website. Can anyone who's done this recently recommend any of the cheap brands from eBay?
Thanks.
#2 boosted
boosted
  • 2080 posts
Posted 30 January 2021 - 04:52 PM
Just wiggle top bottom side to side...itll pop off.
Push/ pull 12 3 6 9 oclock...
#3 atlex
atlex
    Hiding from the Ayatollah or making Full Metal Jacket.
  • 1540 posts
Posted 30 January 2021 - 06:17 PM
 I recommend a rubber mallet wrapped in a t-shirt. or something else like that. tappety tap on the side and from behind. anything should losen it.
#4 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 30 January 2021 - 06:26 PM
Thank you both. Maybe even a weakling like me can do it. I’ll give it a go. Looking forward to posting a pic of my new wheel.
Sent from my iPad using Tapatalk
#5 boosted
boosted
  • 2080 posts
Posted 30 January 2021 - 06:30 PM
You can do it!! My nardi on my mk1 took 15 mins to yield to me.
Good luck
#6 IanC
IanC
  • 272 posts
Posted 30 January 2021 - 09:33 PM
Leave the nut on a couple of turns so you don't get the wheel in your face.
#7 atlex
atlex
  • 1540 posts
Posted 30 January 2021 - 10:04 PM
IanC is wise :-)
lastly.. if you've got a can of compressed air (the kind for cleaning keyboards) you can use it to cool/shrink the nut/spline that wheel is attached to. Or if you've got a little gas jet like the kind used in some soldering irons use that on the metal body of the wheel's boss part, obviously, to cause it to expand... ahem.
#8 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 01 February 2021 - 09:34 AM
You’re right, I don’t want a black eye. Thanks for all the advice and encouragement. I feel a bit better about giving it a go now.
#9 Shadowraven
Shadowraven
  • 4676 posts
Posted 01 February 2021 - 04:17 PM
As above leave the nut on.
I'd try it first, just give it an energetic wiggle and I think you'll fine it'll come off without too much drama, mine was a lot easier than I expected. Just remember the shaft is splined, you arent trying to twist it side to side as it'll just jam up on the splines but break it free front to rear, I found tapping one side then the next in rapid succession like you were drumming was enough and it loosened easily.
#10 Quinvy
Quinvy
    Phil.
  • 1852 posts
Posted 02 February 2021 - 11:44 AM
Mine was a real swine to get off. And I did give myself a very eye watering smack in the mush.
#11 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 03 February 2021 - 09:19 AM
Can’t wait to get busy.
#12 atlex
atlex
  • 1540 posts
Posted 03 February 2021 - 01:52 PM
I've been thinking of my mallet approach :-)
yes, losen the nut but not all the way, as discussed.
then wrap that mallet/heavy object in a towel or something so it can't mar the car or existing wheel
then with the door open hit the wheel from 'behind' below, i.e. from the footpedals up to the bottom/back of the wheel.
then turn the wheel 180 degrees or 90 degrees and repeat.
you need some space to swing, see.
#13 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 03 February 2021 - 08:30 PM
I thought I had to leave the steering wheel straight so I can align the new one?
#14 atlex
atlex
  • 1540 posts
Posted 04 February 2021 - 07:23 PM
Keep the nut on a few turns from tight, this will keep the wheel's boss on at least 50% of the length of the splines, which should be perfectly safe to turn especially with the power steering on.
You're bashing the wheel to loosen up the engagement of the boss with the splines, not to get the wheel off, until you're ready, at which point you take the nut all the way off, ideally with the wheels straight and the steering wheel perfectly level.
#15 Zed.
Zed.
  • 2032 posts
Posted 04 February 2021 - 07:53 PM
just mark the column for the 'straight' direction....
Bodger :ph34r:
#16 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 06 February 2021 - 06:35 PM
Ok thanks. Royal Steering Wheels say it’ll be posted early next week, so it won’t be long now. I’m keen to get it over with.
#17 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 09 February 2021 - 01:27 PM
It arrived!
Slightly thicker, printed leather top/bottom, perforated leather sides, black stitching.
Hoping to fit it Thursday or Friday when there’s someone home to help me.
#18 Sidni7
Sidni7
  • 393 posts
  • Gender:Female
Posted 11 February 2021 - 02:23 PM
In the end, I assisted and hubby did the job.happy to say the old wheel came off very easily. Just needed a couple of light taps. Hardest bit was finding /understanding the torque settings. I believe the correct settings are:-
Centre bolt torque 29-36 inch lbs
Two airbag bolts torque 69-95 Newton-meters
Anyway, all done and I’m super-happy with it. Thanks everyone for the great advice. You were absolutely right that I didn’t need a steering wheel puller. And nobody got a black eye.
#19 boosted
boosted
  • 2080 posts
Posted 11 February 2021 - 02:30 PM
Cool looks smart
#20 atlex
atlex
  • 1540 posts
Posted 11 February 2021 - 08:25 PM
woop!
